I’m having trouble upgrading from build 47 to 49. The first 2 fails I didn’t see as I wasn’t watching the screen, but I returned to find the download progress bar window gone, and nothing else happening. The 3rd attempt completed downloading, but finishing with launching failed - see attached image.
I have not changed any firewall settings since the last update
Attempting to run WebODM failed again when I tried to run it.
“Booting WebODM 1.9.11 build 49…”
“Trying to connect to NodeODM localhost:29301…”
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: No tasks dump found\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: Found orphaned directory: f2937225-f165-4750-b6c9-ba960d523cb1, removing…\r\n”
“Attempt 0 failed, retrying…”
“Attempt 1 failed, retrying…”
“nodeodm: error: EBUSY: resource busy or locked, unlink ‘E:\WebODM\resources\app\apps\NodeODM\data\f2937225-f165-4750-b6c9-ba960d523cb1\odm_report\report.pdf’\r\n”
“nodeodm: exited with code 1”
“(node:2368) UnhandledPromiseRejectionWarning: Error: Exit code: 1\n at ChildProcess. (E:\WebODM\resources\app\utils.js:63:19)\n at ChildProcess.emit (events.js:210:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”
“(node:2368) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)”
“(node:2368) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.”
“Attempt 2 failed, retrying…”
“Attempt 3 failed, retrying…”
“Attempt 4 failed, retrying…”
“Attempt 5 failed, retrying…”
“Attempt 6 failed, retrying…”
“Attempt 7 failed, retrying…”
“Attempt 8 failed, retrying…”
“Attempt 9 failed, retrying…”
“Attempt 10 failed, retrying…”
“Attempt 11 failed, retrying…”
“Attempt 12 failed, retrying…”
“Attempt 13 failed, retrying…”
“Attempt 14 failed, retrying…”
