Diagnostics page and information
Hi.
I have a slight issue/misconception on the WebODM option I installed on my Win PC. Using the system on the mac (docker etc) I see both storage space and memory using and allocation under the menu. However, the using the installation version this does not seem to show the memory space. is this correct, if so what memory allocation is it using and how can i monitor?
I generally monitor memory usage etc in the windows task manager
Native Windows WebODM does not show RAM use, only drive space. As Martin says, Task Manager is easy to use for this purpose, but if you want to see what’s been going on for more than the max 4 mins display time, I use Open Hardware Monitor, which can display for up to 24 hours, and covers a lot more than Task Manager, including temperature sensors.
