I have some questions on Linux:
- In the ODM README, after launching ./start-dev-env.sh, the first command to start is
(odmdev) [user:/code] master+* ± bash configure.sh reinstall
Why not install instead of reinstall ?
- If I exit the dev terminal and I want to restart it with ./start-dev-env.sh, I have the error that the container name already exist. What can I do ?
Is it possible to use ./start-dev-env.sh with Macos ?
Because that will make sure to nuke the “SuperBuild” directory, which needs to be rebuilt (if it exists already).
docker start odmdev
docker exec -ti odmdev bash
su <youruser>
With some adjustments, probably (help us improve the script?)
The first thing I see that’s potentially a problem: the tooling appears to expect X11 to be set up on the host computer (the one running Docker) and I haven’t looked into how much fun that would be to set up on a Mac.
Update: XQuartz is a thing, and it’s running on my MacBook Pro so there’s that.
I just commented out the exit 1
in the Linux check to see what happened. It took forever, but I got the following message:
ODM Dev Environment Ready. Hack on!
I cannot vouch for its completeness or correctness, mind you, but at least it got this far!
Further than I’ve ever managed and I’m on Linux with X11, so you’re doing great
I ran the bash command to rebuild everything, then tried the run command and it’s currently building a dataset. I have no idea why it wants X11, maybe for folks who want to run an GUI editor from within the container, that’s a question for the active contributors.
If that’s all, make that bit optional and Mac folks can start the dev environment!
That’s only so that this allows GUIs like Qt Creator to work; but it’s not required (you can just skip mounting the X11 volumes on Mac).
If my work allowed me to make arbitrary pull requests, I’d make one that did the following:
- removed the Linux check
- checked for
xhost
as is done for docker
- added the X11 volumes to the docker command line if the above check passed, and
- only called it if the above check passed
If a Windows person tries to use it and complains, encourage them to write the code to make it work for Windows.
Ah, well, those policies are unfortunate.
Make sure your employer is aware of their licensing responsibilities too! ODM/LICENSE at master · OpenDroneMap/ODM · GitHub
Alas, my company has a team of lawyers and software folks (hopefully more of the latter than the former) that would keep us from using AGPL-licensed software in the general case. If the rules change, you’ll be among the first to know.
Always a challenge, and I have been surprised by how often lawyers get GPL and AGPL wrong: I have gently corrected very expensive IP lawyers on calls regarding obligations under licenses.
(FYI, I am not a lawyer…)
For a good review of the myths around AGPL, check out this: The falsehoods of anti-AGPL propaganda
And share with your lawyers! Hopefully they are as patient as the ones I have encountered.
ht: Piero for sharing that article or some iteration of it with me.
