After a while I revisited a dataset which I have processed already several times with ODM, with success. I used the original aerial images and preprocessed ones. Preprocessing was about colour alignment of the thermal images which came with different colour palettes. Even with the preprocessed images the resulting orthophoto was very good, qualitiy of “stitching” was way better than when using the original thermal images. However, I tweaked a little bit the preprocessing, and now DensifyPointCloud
failes with a segfault.
What can go wrong here?
[INFO] running "/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud" "/var/www/data/31cc6831-cd87-49a1-bd6b-d75908520a23/opensfm/undistorted/openmvs/scene.mvs" --resolution-level 0 --dense-config-file "/var/www/data/31cc6831-cd87-49a1-bd6b-d75908520a23/opensfm/undistorted/openmvs/Densify.ini" --min-resolution 2000 --max-resolution 2000 --max-threads 8 --number-views-fuse 2 --sub-resolution-levels 2 -w "/var/www/data/31cc6831-cd87-49a1-bd6b-d75908520a23/opensfm/undistorted/openmvs/depthmaps" -v 0 --cuda-device -2 --geometric-iters 0
21:49:20 [App ] Build date: Aug 13 2022, 05:58:21
21:49:20 [App ] CPU: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz (8 cores)
21:49:20 [App ] RAM: 30.64GB Physical Memory 8.20GB Virtual Memory
21:49:20 [App ] OS: Linux 5.10.0-19-amd64 (x86_64)
21:49:20 [App ] Disk: 672.13GB (907.75GB) space
21:49:20 [App ] SSE & AVX compatible CPU & OS detected
21:49:20 [App ] Command line: DensifyPointCloud /var/www/data/31cc6831-cd87-49a1-bd6b-d75908520a23/opensfm/undistorted/openmvs/scene.mvs --resolution-level 0 --dense-config-file /var/www/data/31cc6831-cd87-49a1-bd6b-d75908520a23/opensfm/undistorted/openmvs/Densify.ini --min-resolution 2000 --max-resolution 2000 --max-threads 8 --number-views-fuse 2 --sub-resolution-levels 2 -w /var/www/data/31cc6831-cd87-49a1-bd6b-d75908520a23/opensfm/undistorted/openmvs/depthmaps -v 0 --cuda-device -2 --geometric-iters 0
21:49:20 [App ] The camera directions mean is unbalanced; the scene will be considered unbounded (no ROI)
Segmentation fault (core dumped)
Child returned 139
File "/code/stages/odm_app.py", line 88, in execute
File "/code/opendm/types.py", line 378, in run
File "/code/opendm/types.py", line 359, in run
File "/code/stages/openmvs.py", line 114, in process
raise e
File "/code/stages/openmvs.py", line 105, in process
run_densify()
File "/code/stages/openmvs.py", line 100, in run_densify
system.run('"%s" "%s" %s' % (context.omvs_densify_path,
opendm.system.SubprocessException: Child returned 139
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying/
Parameters:
auto-boundary: true, depthmap-resolution: 2000, dsm: true, feature-quality: ultra, gps-accuracy: 3, mesh-octree-depth: 13, mesh-size: 600000, min-num-features: 25000, orthophoto-cutline: true, orthophoto-resolution: 1, pc-quality: ultra, rerun-from: dataset, skip-3dmodel: true, verbose: true
After preprocessing the EXIF data is transferred from original images.
