I’m encountering an error after matching about which I can’t find any information. Image matching seems to work fine (matched 7383 pairs), then i get:
[WARNING] Submodels directory already exist at: /code/submodels
followed by:
[INFO] Dataset has been split into 0 submodels. Reconstructing each submodel…
The rest of the steps run and fail because there’s no data to process:
[INFO] Aligning submodels…
[INFO] Finished split stage
[INFO] Running merge stage
[WARNING] No input point cloud files to process
[INFO] Merging all crop bounds: []
[WARNING] No bounds found for any submodel.
[WARNING] No orthophoto/cutline pairs were found in any of the submodels. No orthophoto will be generated.
[INFO] Merging 0 shots.geojson files
[INFO] Finished merge stage
[INFO] Running odm_postprocess stage
[INFO] Post Processing
[INFO] Finished odm_postprocess stage
[INFO] No more stages to run
I have WebODM installed and running on Docker (MacOS), and I’m using the command line to run the following:
docker run -it --rm
-v “$(pwd)/images:/code/images”
-v “$(pwd)/odm_georeferencing:/code/odm_georeferencing”
-v “$(pwd)/odm_meshing:/code/odm_meshing”
-v “$(pwd)/odm_orthophoto:/code/odm_orthophoto”
-v “$(pwd)/odm_texturing:/code/odm_texturing”
-v “$(pwd)/opensfm:/code/opensfm”
-v “$(pwd)/smvs:/code/smvs”
-v “$(pwd)/submodels:/code/submodels”
opendronemap/odm --skip-3dmodel --fast-orthophoto --ignore-gsd --orthophoto-resolution 2 --verbose --texturing-data-term area --split 400
I’m processing 779 images, so attempting to split them roughly into two sets with split-merge.
Any help much appreciated!
