Dashboard task running [not starting] - completes the task on webodm.net/dashboard
Hello all - I have frequent problems with uploading tasks using the lightning node.
It all (images + gcps) upload fine but it will not complete on the webodm dashboard. It is just stuck in running mode and if I refresh the browser the time-counter goes back to zero.
The task always completes (behind the scene) and uploads the all assets to webodm.net/dashboard.
I then download the zip from webodm.net/dashboard and upload it again creating a new task on the webodm dashboard and all works fine.
But why ??
Are you using the lightning desktop app? If so, could you open the app logs directory (from one of the top menus) and copy/paste the logs here? They might have some clues.
No - not using the desktop app. Running webodm from a Ubuntu server. The task will not generate any logs / task outputs what I can see.
