APOS80
17 December 2022 20:10
I think I need to do a crosshatch flight to get the accuracy I need.
But I’m the apps like Pix4D or GoodStation you set the overlap but if seems to be the overlap for every individual flight.
So how should I about overlap? As it’s two flights that overlap then a lower individual overlap is the right thing?
And maybe ten degrees from nadir?
Have you checked out Stephen’s excellent blog series on flight planning?:
See these four blogs by Stephen Mather (smathermather-cm) for some great guidance on flight planning:
Also, depending upon your sUAS platform, there may be a bunch of different Flight Planning apps that may help you as well.
Every time I see this I have pangs of guilt that I haven’t updated it…
Honestly Pix4Dcapture’s crosshatch setting is basically perfect as-is. You want good orthos, make sure you have enough 10-degree shots. You want good 3D, make sure your total overlap is 83% and you have lots of 45-degree shots. But keep it to 75% otherwise.
APOS80
18 December 2022 06:39
#4
”Total overlap”, does that mean the total overlap after two flights? In that case what would be the overlap of the first flight?
Gordon
18 December 2022 08:31
#5
I think 60% in each direction will give you close to 85% total
APOS80
18 December 2022 08:54
#6
Yes, it must be like that.
