Create GCPs from point cloud local coordinates from laser scanner to Improve accuracy
I have a project that is scanned with a laser scanner that have local coordinates.
If I pick out clear points from the point cloud that is easy to recognize in the images, is it possible to use those points as GCPs to improve accuracy?
Any suggestions on how a work flow like that would look like to be able to make it work?
If you can get the precise XYZ location of those points from the scanned LiDAR Point Cloud in the same CRS as the images (or convert it), then I don’t see why it would not work!
Let us know how you get on!
