Data set is fine at low settings no problem but increase settings like Depthmap to 2000 and min-num-features to 20000 most of the times it crashed but few times worked fine…all software up to date
Bill
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 1.2
[INFO] depthmap_resolution: 2000.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: ultra
[INFO] feature_type: hahog
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 2.0
[INFO] ignore_gsd: True
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 48
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 20000
[INFO] name: 083e3d1f-dfc5-4e03-ad7d-855c69ef58d2
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 0.7
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: ultra
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘odm_report’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] texturing_data_term: area
[INFO] texturing_tone_mapping: gamma
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: True
[INFO] use_exif: False
[INFO] verbose: False
[INFO] ==============
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/images
[INFO] Loading images database: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/images.json
[INFO] Found 164 usable images
[INFO] Coordinates file already exist: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/odm_georeferencing/coords.txt
[INFO] Model geo file already exist: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/odm_georeferencing/odm_georeferencing_model_geo.txt
[INFO] Parsing SRS header: WGS84 UTM 19N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/image_list.txt already exists, not rerunning OpenSfM setup
[WARNING] Detect features already done: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/features exists
[WARNING] Match features already done: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/matches exists
[WARNING] Found a valid OpenSfM tracks file in: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/tracks.csv
[WARNING] Found a valid OpenSfM reconstruction file in: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/reconstruction.json
[INFO] Already extracted cameras
[WARNING] Found existing reconstruction stats /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/stats/stats.json
[WARNING] Will skip exporting /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/reconstruction.geocoords.json
[WARNING] Legacy option --depthmap-resolution (this might be removed in a future version). Use --pc-quality instead.
[INFO] Undistorting /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm …
[WARNING] Already undistorted (nominal)
[WARNING] Found a valid OpenSfM NVM reconstruction file in: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/undistorted/reconstruction.nvm
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[WARNING] Found existing /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/undistorted/openmvs/scene.mvs
[INFO] Estimating depthmaps
[INFO] running /code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud “/var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 1 --min-resolution 2000 --max-resolution 4608 --max-threads 48 --number-views-fuse 2 -w “/var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/undistorted/openmvs/depthmaps” -v 0
16:27:25 [App ] Build date: Mar 31 2021, 18:59:43
16:27:25 [App ] CPU: AMD Ryzen Threadripper 3960X 24-Core Processor (48 cores)
16:27:25 [App ] RAM: 100.51GB Physical Memory 26.00GB Virtual Memory
16:27:25 [App ] OS: Linux 5.4.72-microsoft-standard-WSL2 (x86_64)
16:27:25 [App ] SSE & AVX compatible CPU & OS detected
16:27:25 [App ] Command line: /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/undistorted/openmvs/scene.mvs --resolution-level 1 --min-resolution 2000 --max-resolution 4608 --max-threads 48 --number-views-fuse 2 -w /var/www/data/083e3d1f-dfc5-4e03-ad7d-855c69ef58d2/opensfm/undistorted/openmvs/depthmaps -v 0
16:27:30 [App ] Selecting images for dense reconstruction completed: 164 images (1s420ms)
Estimated depth-maps 1 (0.61%, 700ms, ETA 0ms)…
Estimated depth-maps 2 (1.22%, 952ms, ETA 1m)…
Estimated depth-maps 3 (1.83%, 1s, ETA 1m)…
Estimated depth-maps 4 (2.44%, 1s, ETA 1m)…
Estimated depth-maps 5 (3.05%, 2s, ETA 1m)…
Estimated depth-maps 6 (3.66%, 2s, ETA 1m)…
Estimated depth-maps 7 (4.27%, 3s, ETA 1m)…
Estimated depth-maps 8 (4.88%, 3s, ETA 1m)…
Estimated depth-maps 9 (5.49%, 4s, ETA 1m)…
Estimated depth-maps 11 (6.71%, 4s, ETA 1m)…
Estimated depth-maps 12 (7.32%, 5s, ETA 1m)…
Estimated depth-maps 14 (8.54%, 6s, ETA 1m)…
Estimated depth-maps 15 (9.15%, 6s, ETA 1m)…
Estimated depth-maps 16 (9.76%, 7s, ETA 1m)…
Estimated depth-maps 17 (10.37%, 7s, ETA 1m)…
Estimated depth-maps 18 (10.98%, 8s, ETA 1m)…
Estimated depth-maps 19 (11.59%, 9s, ETA 1m)…
Estimated depth-maps 20 (12.20%, 9s, ETA 1m)…
Estimated depth-maps 21 (12.80%, 9s, ETA 1m)…
Estimated depth-maps 22 (13.41%, 11s, ETA 1m)…
Estimated depth-maps 24 (14.63%, 12s, ETA 1m)…
Estimated depth-maps 25 (15.24%, 12s, ETA 1m)…
Estimated depth-maps 26 (15.85%, 13s, ETA 1m)…
Estimated depth-maps 28 (17.07%, 14s, ETA 1m)…
Estimated depth-maps 29 (17.68%, 14s, ETA 1m)…
Estimated depth-maps 30 (18.29%, 16s, ETA 1m)…
Estimated depth-maps 31 (18.90%, 16s, ETA 1m)…
Estimated depth-maps 32 (19.51%, 17s, ETA 1m)…
Estimated depth-maps 33 (20.12%, 17s, ETA 1m)…
Estimated depth-maps 34 (20.73%, 18s, ETA 1m)…
Estimated depth-maps 36 (21.95%, 19s, ETA 1m)…
Estimated depth-maps 37 (22.56%, 20s, ETA 1m)…
Estimated depth-maps 38 (23.17%, 21s, ETA 1m)…
Estimated depth-maps 39 (23.78%, 21s, ETA 1m)…
Estimated depth-maps 40 (24.39%, 22s, ETA 1m)…
Estimated depth-maps 42 (25.61%, 23s, ETA 1m)…
Estimated depth-maps 44 (26.83%, 24s, ETA 1m)…
Estimated depth-maps 46 (28.05%, 25s, ETA 1m)…
Estimated depth-maps 48 (29.27%, 27s, ETA 1m)…
Estimated depth-maps 50 (30.49%, 28s, ETA 1m)…
Estimated depth-maps 52 (31.71%, 29s, ETA 1m)…
Estimated depth-maps 54 (32.93%, 30s, ETA 1m)…
Estimated depth-maps 55 (33.54%, 30s, ETA 1m)…
Estimated depth-maps 56 (34.15%, 31s, ETA 1m)…
Estimated depth-maps 57 (34.76%, 31s, ETA 59s)…
Estimated depth-maps 58 (35.37%, 32s, ETA 58s)…
Estimated depth-maps 59 (35.98%, 32s, ETA 57s)…
Estimated depth-maps 60 (36.59%, 33s, ETA 57s)…
Estimated depth-maps 61 (37.20%, 33s, ETA 56s)…
Estimated depth-maps 62 (37.80%, 34s, ETA 56s)…
Estimated depth-maps 63 (38.41%, 34s, ETA 55s)…
Estimated depth-maps 64 (39.02%, 35s, ETA 55s)…
Estimated depth-maps 66 (40.24%, 36s, ETA 53s)…
Estimated depth-maps 67 (40.85%, 36s, ETA 52s)…
Estimated depth-maps 68 (41.46%, 37s, ETA 52s)…
Estimated depth-maps 69 (42.07%, 37s, ETA 51s)…
Estimated depth-maps 70 (42.68%, 38s, ETA 51s)…
Estimated depth-maps 72 (43.90%, 39s, ETA 50s)…
Estimated depth-maps 74 (45.12%, 40s, ETA 48s)…
Estimated depth-maps 76 (46.34%, 41s, ETA 47s)…
Estimated depth-maps 78 (47.56%, 41s, ETA 46s)…
Estimated depth-maps 79 (48.17%, 42s, ETA 45s)…
Estimated depth-maps 80 (48.78%, 42s, ETA 44s)…
Estimated depth-maps 81 (49.39%, 42s, ETA 43s)…
Estimated depth-maps 82 (50.00%, 43s, ETA 43s)…
Estimated depth-maps 83 (50.61%, 44s, ETA 43s)…
Estimated depth-maps 84 (51.22%, 44s, ETA 42s)…
Estimated depth-maps 85 (51.83%, 45s, ETA 41s)…
Estimated depth-maps 86 (52.44%, 45s, ETA 41s)…
Estimated depth-maps 87 (53.05%, 45s, ETA 40s)…
Estimated depth-maps 88 (53.66%, 47s, ETA 40s)…
Estimated depth-maps 90 (54.88%, 48s, ETA 39s)…
Estimated depth-maps 91 (55.49%, 49s, ETA 39s)…
Estimated depth-maps 93 (56.71%, 50s, ETA 38s)…
Estimated depth-maps 94 (57.32%, 50s, ETA 37s)…
Estimated depth-maps 95 (57.93%, 51s, ETA 37s)…
Estimated depth-maps 96 (58.54%, 51s, ETA 36s)…
Estimated depth-maps 97 (59.15%, 52s, ETA 36s)…
Estimated depth-maps 99 (60.37%, 53s, ETA 34s)…
Estimated depth-maps 100 (60.98%, 53s, ETA 34s)…
Estimated depth-maps 101 (61.59%, 53s, ETA 33s)…
Estimated depth-maps 102 (62.20%, 54s, ETA 32s)…
Estimated depth-maps 103 (62.80%, 54s, ETA 32s)…
Estimated depth-maps 104 (63.41%, 55s, ETA 31s)…
Estimated depth-maps 105 (64.02%, 55s, ETA 31s)…
Estimated depth-maps 106 (64.63%, 55s, ETA 30s)…
Estimated depth-maps 107 (65.24%, 56s, ETA 30s)…
Estimated depth-maps 109 (66.46%, 57s, ETA 28s)…
Estimated depth-maps 111 (67.68%, 58s, ETA 27s)…
Estimated depth-maps 112 (68.29%, 58s, ETA 27s)…
Estimated depth-maps 113 (68.90%, 58s, ETA 26s)…
Estimated depth-maps 114 (69.51%, 59s, ETA 25s)…
Estimated depth-maps 115 (70.12%, 59s, ETA 25s)…
Estimated depth-maps 116 (70.73%, 59s, ETA 24s)…
Estimated depth-maps 117 (71.34%, 1m, ETA 24s)…
Estimated depth-maps 118 (71.95%, 1m, ETA 23s)…
Estimated depth-maps 119 (72.56%, 1m1s, ETA 23s)…
Estimated depth-maps 120 (73.17%, 1m1s, ETA 22s)…
Estimated depth-maps 121 (73.78%, 1m2s, ETA 22s)…
Estimated depth-maps 122 (74.39%, 1m2s, ETA 21s)…
Estimated depth-maps 123 (75.00%, 1m2s, ETA 20s)…
Estimated depth-maps 124 (75.61%, 1m3s, ETA 20s)…
Estimated depth-maps 125 (76.22%, 1m3s, ETA 19s)…
Estimated depth-maps 126 (76.83%, 1m3s, ETA 19s)…
Estimated depth-maps 127 (77.44%, 1m4s, ETA 18s)…
Estimated depth-maps 128 (78.05%, 1m4s, ETA 18s)…
Estimated depth-maps 129 (78.66%, 1m5s, ETA 17s)…
Estimated depth-maps 130 (79.27%, 1m5s, ETA 17s)…
Estimated depth-maps 131 (79.88%, 1m5s, ETA 16s)…
Estimated depth-maps 132 (80.49%, 1m6s, ETA 16s)…
Estimated depth-maps 133 (81.10%, 1m6s, ETA 15s)…
Estimated depth-maps 134 (81.71%, 1m7s, ETA 15s)…
Estimated depth-maps 136 (82.93%, 1m8s, ETA 14s)…
Estimated depth-maps 138 (84.15%, 1m8s, ETA 12s)…
Estimated depth-maps 140 (85.37%, 1m9s, ETA 11s)…
Estimated depth-maps 141 (85.98%, 1m9s, ETA 11s)…
Estimated depth-maps 142 (86.59%, 1m10s, ETA 10s)…
Estimated depth-maps 143 (87.20%, 1m10s, ETA 10s)…
Estimated depth-maps 144 (87.80%, 1m11s, ETA 9s)…
Estimated depth-maps 146 (89.02%, 1m12s, ETA 8s)…
Estimated depth-maps 147 (89.63%, 1m12s, ETA 8s)…
Estimated depth-maps 148 (90.24%, 1m13s, ETA 7s)…
Estimated depth-maps 149 (90.85%, 1m13s, ETA 7s)…
Estimated depth-maps 150 (91.46%, 1m13s, ETA 6s)…
Estimated depth-maps 152 (92.68%, 1m14s, ETA 5s)…
Estimated depth-maps 154 (93.90%, 1m15s, ETA 4s)…
Estimated depth-maps 156 (95.12%, 1m16s, ETA 3s)…
Estimated depth-maps 158 (96.34%, 1m17s, ETA 2s)…
Estimated depth-maps 159 (96.95%, 1m17s, ETA 2s)…
Estimated depth-maps 160 (97.56%, 1m18s, ETA 1s)…
Estimated depth-maps 162 (98.78%, 1m19s, ETA 975ms)…
Estimated depth-maps 163 (99.39%, 1m19s, ETA 486ms)…
Estimated depth-maps 164 (100.00%, 1m19s, ETA 0ms)…
Estimated depth-maps 164 (100%, 1m19s847ms)
Filtered depth-maps 1 (0.61%, 37s, ETA 0ms)…
Filtered depth-maps 2 (1.22%, 37s, ETA 50m)…
Filtered depth-maps 3 (1.83%, 37s, ETA 33m)…
Filtered depth-maps 4 (2.44%, 38s, ETA 25m)…
Filtered depth-maps 5 (3.05%, 39s, ETA 20m)…
Filtered depth-maps 6 (3.66%, 39s, ETA 17m)…
Filtered depth-maps 7 (4.27%, 39s, ETA 14m)…
Filtered depth-maps 8 (4.88%, 40s, ETA 13m)…
Filtered depth-maps 9 (5.49%, 41s, ETA 11m)…
Filtered depth-maps 10 (6.10%, 41s, ETA 10m)…
Filtered depth-maps 11 (6.71%, 42s, ETA 9m)…
Filtered depth-maps 12 (7.32%, 44s, ETA 9m)…
Filtered depth-maps 13 (7.93%, 45s, ETA 8m)…
Filtered depth-maps 14 (8.54%, 46s, ETA 8m)…
Filtered depth-maps 15 (9.15%, 47s, ETA 7m)…
Filtered depth-maps 16 (9.76%, 48s, ETA 7m)…
Filtered depth-maps 17 (10.37%, 49s, ETA 7m)…
Filtered depth-maps 18 (10.98%, 50s, ETA 6m)…
Filtered depth-maps 19 (11.59%, 51s, ETA 6m)…
Filtered depth-maps 20 (12.20%, 52s, ETA 6m)…
Filtered depth-maps 21 (12.80%, 53s, ETA 6m)…
Filtered depth-maps 22 (13.41%, 54s, ETA 5m)…
Filtered depth-maps 23 (14.02%, 54s, ETA 5m)…
Filtered depth-maps 24 (14.63%, 55s, ETA 5m)…
Filtered depth-maps 25 (15.24%, 56s, ETA 5m)…
Filtered depth-maps 26 (15.85%, 57s, ETA 5m)…
Filtered depth-maps 27 (16.46%, 58s, ETA 4m)…
Filtered depth-maps 28 (17.07%, 58s, ETA 4m)…
Filtered depth-maps 29 (17.68%, 58s, ETA 4m)…
Filtered depth-maps 30 (18.29%, 58s, ETA 4m)…
Filtered depth-maps 31 (18.90%, 1m, ETA 4m)…
Filtered depth-maps 33 (20.12%, 1m, ETA 3m)…
Filtered depth-maps 34 (20.73%, 1m1s, ETA 3m)…
Filtered depth-maps 35 (21.34%, 1m2s, ETA 3m)…
Filtered depth-maps 36 (21.95%, 1m3s, ETA 3m)…
Filtered depth-maps 38 (23.17%, 1m3s, ETA 3m)…
Filtered depth-maps 39 (23.78%, 1m5s, ETA 3m)…
Filtered depth-maps 40 (24.39%, 1m5s, ETA 3m)…
Filtered depth-maps 41 (25.00%, 1m5s, ETA 3m)…
Filtered depth-maps 42 (25.61%, 1m6s, ETA 3m)…
Filtered depth-maps 43 (26.22%, 1m6s, ETA 3m)…
Filtered depth-maps 44 (26.83%, 1m8s, ETA 3m)…
Filtered depth-maps 47 (28.66%, 1m8s, ETA 2m)…
Filtered depth-maps 49 (29.88%, 1m9s, ETA 2m)…
Filtered depth-maps 54 (32.93%, 1m9s, ETA 2m)…
Filtered depth-maps 57 (34.76%, 1m10s, ETA 2m)…
Filtered depth-maps 58 (35.37%, 1m11s, ETA 2m)…
Filtered depth-maps 60 (36.59%, 1m11s, ETA 2m)…
Filtered depth-maps 62 (37.80%, 1m11s, ETA 1m)…
Filtered depth-maps 65 (39.63%, 1m11s, ETA 1m)…
Filtered depth-maps 68 (41.46%, 1m11s, ETA 1m)…
Filtered depth-maps 71 (43.29%, 1m11s, ETA 1m)…
Filtered depth-maps 74 (45.12%, 1m11s, ETA 1m)…
Filtered depth-maps 77 (46.95%, 1m12s, ETA 1m)…
Filtered depth-maps 80 (48.78%, 1m12s, ETA 1m)…
Filtered depth-maps 83 (50.61%, 1m12s, ETA 1m)…
Filtered depth-maps 86 (52.44%, 1m12s, ETA 1m)…
Filtered depth-maps 89 (54.27%, 1m12s, ETA 1m)…
Filtered depth-maps 92 (56.10%, 1m12s, ETA 56s)…
Filtered depth-maps 95 (57.93%, 1m12s, ETA 52s)…
Filtered depth-maps 98 (59.76%, 1m13s, ETA 49s)…
Filtered depth-maps 100 (60.98%, 1m13s, ETA 46s)…
Filtered depth-maps 102 (62.20%, 1m24s, ETA 51s)…
Filtered depth-maps 105 (64.02%, 1m24s, ETA 47s)…
Filtered depth-maps 108 (65.85%, 1m24s, ETA 43s)…
Filtered depth-maps 111 (67.68%, 1m24s, ETA 40s)…
Filtered depth-maps 114 (69.51%, 1m25s, ETA 37s)…
Filtered depth-maps 117 (71.34%, 1m25s, ETA 34s)…
Filtered depth-maps 120 (73.17%, 1m25s, ETA 31s)…
Filtered depth-maps 123 (75.00%, 1m25s, ETA 28s)…
Filtered depth-maps 126 (76.83%, 1m25s, ETA 25s)…
Filtered depth-maps 129 (78.66%, 1m25s, ETA 23s)…
Filtered depth-maps 132 (80.49%, 1m25s, ETA 20s)…
Filtered depth-maps 133 (81.10%, 1m27s, ETA 20s)…
Filtered depth-maps 136 (82.93%, 1m27s, ETA 17s)…
Filtered depth-maps 139 (84.76%, 1m27s, ETA 15s)…
Filtered depth-maps 140 (85.37%, 1m46s, ETA 18s)…
Filtered depth-maps 141 (85.98%, 1m50s, ETA 17s)…
Filtered depth-maps 143 (87.20%, 1m52s, ETA 16s)…
Filtered depth-maps 145 (88.41%, 1m53s, ETA 14s)…
Filtered depth-maps 146 (89.02%, 1m54s, ETA 14s)…
Filtered depth-maps 147 (89.63%, 1m55s, ETA 13s)…
Filtered depth-maps 148 (90.24%, 1m56s, ETA 12s)…
Filtered depth-maps 149 (90.85%, 1m56s, ETA 11s)…
Filtered depth-maps 150 (91.46%, 1m56s, ETA 10s)…
Filtered depth-maps 151 (92.07%, 1m57s, ETA 10s)…
Filtered depth-maps 152 (92.68%, 1m57s, ETA 9s)…
Filtered depth-maps 153 (93.29%, 1m57s, ETA 8s)…
Filtered depth-maps 154 (93.90%, 1m58s, ETA 7s)…
Filtered depth-maps 155 (94.51%, 1m58s, ETA 6s)…
Filtered depth-maps 156 (95.12%, 1m59s, ETA 6s)…
Filtered depth-maps 157 (95.73%, 1m59s, ETA 5s)…
Filtered depth-maps 158 (96.34%, 2m, ETA 4s)…
Filtered depth-maps 159 (96.95%, 2m, ETA 3s)…
Filtered depth-maps 160 (97.56%, 2m, ETA 3s)…
Filtered depth-maps 161 (98.17%, 2m1s, ETA 2s)…
Filtered depth-maps 162 (98.78%, 2m2s, ETA 1s)…
Filtered depth-maps 163 (99.39%, 2m2s, ETA 752ms)…
Filtered depth-maps 164 (100.00%, 2m2s, ETA 0ms)…
Filtered depth-maps 164 (100%, 2m2s874ms)
Segmentation fault
File “/code/run.py”, line 68, in
app.execute()
File “/code/stages/odm_app.py”, line 82, in execute
File “/code/opendm/types.py”, line 338, in run
File “/code/opendm/types.py”, line 319, in run
File “/code/stages/openmvs.py”, line 77, in process
system.run(’%s “%s” %s’ % (context.omvs_densify_path,
Exception: Child returned 139
