Link to dataset : https://www.dropbox.com/sh/0hfnz7q9lfll56e/AADh8t3ssyVdJxqs28ZPrIRda?dl=0
I had no issue using webodm for this dataset back in February which I think was using V0.4.2. I did an update and currently I run into an error right after loading the images. The dataset doesn’t have EXIF or GCP but I was able to get it running with no issue 2 months ago. Please help!
Blockquote
[DEBUG] Loaded Sidney_7-26_2nd_00901.jpg | camera: | dimensions: 4096 x 2160 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[INFO] Found 27 usable images
[WARNING] Could not generate coordinates file. Ignore if there is a GCP file. Error: logFile_ was set to: /var/www/data/de9342f6-0a45-47b0-9f66-9fcad3f55d23/odm_georeferencing/odm_georeferencing_utm_log.txt
Error in OdmExtractUtm:
Sidney_7-26_2nd_01036.jpg: No Exif data found in the file
For more detailed information, see log file.
[ERROR] Could not find file /var/www/data/de9342f6-0a45-47b0-9f66-9fcad3f55d23/odm_georeferencing/coords.txt
plasm.execute(niter=1)
File “/code/scripts/dataset.py”, line 116, in process
f.write(outputs.reconstruction.projection.srs)
AttributeError: ‘NoneType’ object has no attribute ‘srs’
Blockquote
