Could not download WebODM.
Help me
Unable to download
WebODM1
Make sure you are not connected to VPN, that you can access https://github.com/OpenDroneMap/WebODM/ and that something in your network is not interfering with the secure connection to github (what country are you connecting from?)
I am connected from Japan.
https: //github.com/OpenDroneMap/WebODM/
We have confirmed that we can connect to this.
Mm, as a workaround, you can manually download the WebODM folder (click https://github.com/OpenDroneMap/WebODM/archive/master.zip), extract it in C:\WebODM Manager and rename the extracted folder to “WebODM” so that the path C:\WebODM Manager\WebODM\README.md exists, then restart WebODM Manager.
Thank you for your help
I get the following error
./webodm.sh: line 3: dirname: command not found
./webodm.sh: line 3: cd: HOME not set
./webodm.sh: line 7: uname: command not found
Error: Update exited with code: 127
Is there a “Git Bash” application installed on your computer? Are you able to launch it? (From the error messages it looks like it didn’t install correctly). https://git-scm.com/download/win
I deleted Git-based apps
                    [02]: Hyper-V Virtual Ethernet Adapter
Hyper-V の要件: ハイパーバイザーが検出されました。Hyper-V に必要な機能は表示されません。
Detected Windows 10 with Hyper-V support
Initializing console…
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Client: Docker Engine - Community
Version: 19.03.8
API version: 1.40
Go version: go1.12.17
Git commit: afacb8b
Built: Wed Mar 11 01:23:10 2020
OS/Arch: windows/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.8
API version: 1.40 (minimum version 1.12)
Git commit: afacb8b
Built: Wed Mar 11 01:29:16 2020
OS/Arch: linux/amd64
Experimental: false
containerd:
Version: v1.2.13
GitCommit: 7ad184331fa3e55e52b890ea95e65ba581ae3429
runc:
Version: 1.0.0-rc10
GitCommit: dc9208a3303feef5b3839f4323d9beb36df0a9dd
docker-init:
Version: 0.18.0
GitCommit: fec3683
Press Start WebODM to launch
Error: webodm.sh down exited with code: 1
You need the git based apps. Install them from https://git-scm.com/download/win
I installed Git.
The app worked successfully.
Meme probleme pour moi
