Some discrepancies in the console timing:
2021-11-06 14:25:27,542 INFO: Matched 10010 pairs (brown-brown: 10010) in 14554.645498599999 seconds (1.4540105393906093 seconds/pair).
which is 4.04 hours, yet the little clock timer said 3h 53m!
Also I noticed in the large area ortho I (mostly) completed earlier today the console log time stamps have a massive (>17 hours) gap between these steps:
2021-11-05 13:21:44,103 DEBUG: Undistorting image DJI_0982_5.JPG
[INFO] running E:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_visualsfm --points “E:\WebODM\resources\app\apps\NodeODM\data\ebbf01ab-138e-41c8-bcaa-fd6d0c7ad268\opensfm”
[INFO] Finished opensfm stage
and
2021-11-06 08:23:48,180 DEBUG: Final doc sections size summary
I also see a time discrepancy in the dashboard clock. However if you leave the dashboard and go to say diagnostics then back again to dashboard the clock time is refreshed correctly. I havent followed up on whether this time lag carries over to the logs.
That is a separate issue, I’d already gone to diagnostics to make it update in the example above. Before I made it update, it said it had only been going for 43 minutes, even though it had started hours earlier and I’d had time for riding my mountain bike 60km!
Is there any way the green progress bar be made a bit more linear in its representation of progress?
I’ve been keeping an eye on it for many tasks, and notice the last half represents hardly any time, but today I quantified it.
3530 images M2P images resized 0.5X, Options: crop: 0, dem-resolution: 5, dtm: true, feature-type: orb, matcher-distance: 50, matcher-neighbors: 25, mesh-octree-depth: 12, mesh-size: 250000, min-num-features: 30000, orthophoto-resolution: 5, pc-quality: high
Progress bar was almost exactly half way at 27h 38m, and the job finished at 28h 04m. The 2nd half of the progress bar represented just 1.5% of the total time in this case.
