I’m getting this warning - warn: Cannot update info for x.x.x.x:3000: connect ECONNREFUSED x.x.x.x:3000
At the very end of the autoscaling node launch (docker-machine create …). WebODM throws an error and fails at roughly the same point. However, the new node has been added to the node list with an [A] indicating it autoscaled. I can then restart processing in WebODM and things appear to work fine up to the final write of results to S3 where I’m getting a permissions failure.
In researching this on the docker side, it looks like the connection refused message might be coming from a mismatch in the docker IP’s of the two containers. A fix is suggested to bind the http server to 0.0.0.0 in the docker call so that listening will occur on all interfaces. Unfortunately, this is another code change which I’m not excited to suggest since everyone else running AWS is apparently successful.
Thoughts and suggestions appreciated!
