Compressing all.zip - WebODM hang on
i have issue.
Running WebODM with auto node or on ClusterODM + NodeODM or ClusterODM + 2x NodeODM
at the end the process are always hanging on “Compressing all.zip” and stuck, even if i render small project - about 100-150pics.
i have 128GB ram on main machine and 32GB on second, both run on Ubuntu 18.04,
both have 512GB ssd disc, so there is enough ram and disc space.
i tryed restart the project from Orthophoto stage but they nothing helped.
do you have any idea what can i do befor i reinstall both machine? :wink:
ps. what is a dependency after stage:
Adding 0 - odm_georeferencing/odm_georeferenced_model.laz
Pushes complete - joining…
some time time shows only simply "Done!" and then project are finished,
but some times shows:
Done 0
Reawakened: 4534
Saving registry...
Saving metadata...
Index completed in 06:54.
Save complete.
	Points inserted: 82,560,166
Compressing all.zip
and then stuck.
Check the webodm worker’s logs.
docker logs worker
Anything suspicious there?
I have the same issue as “machinefly”.
My PC Ram is 32 GB and 500 Gb of storage.
I have already re-run four projects and they always hang on compresing All.zip .
Does anyone has a solution to break true.
Best regards.
@AnafPro
i solved this issue running NodeODM with parameter
-v /home/user/NodeODM:/var/www/data
where /home/user/NodeODM is folder created by my own
and secondly run WebODM with flag --media-dir /home/user/web
./webodm.sh --media-dir /home/user/web
and even when the proces hang on ziping then i have easy access to project folder and can zip it and import to WebODM.
maybe it is no pro solution but works for me
Thanks for the solution but I’m just a rookie in WebODM and I don’t know where to hit those command line in WebODM. So it will be very helpful if you show me some screenshots.
