Hi All,
Not sure if the question has been asked before but i’m trying to see if there’s a way to do a comparison of two ortho images taken on different days from within the WebODM application? Any help would be greatly appreciated.
Thanks!
Hi All,
Thanks!
Hi @ArchLenz,
You could use the share link(located at the bottom right corner of screen) from each of the two separate days within the same project and open them on two browsers (or tabs) and could navigate separately on each at same location. There is no comparison as of now implemented within WEBODM.
use the “link” text shown on the bottom right area in above image and open in two browser windows.
Hi @ArchLenz
If the two orthophotos are within the same project and task, maybe this publication will help you:
I hope this helps you
Regards,
Thank you, that’s definitely an option for now.
Thank you
hello @ArchLenz again! Outside of WebODM, this is a great option for comparison:
Regards from Colombia!
