Command misconfigured or not supported images?
I am trying to run my fisrt mapping processing, but I am struggling with the error above (all needed info are indicated on the screenshot). It seems obvious that JPG images are supported, if so, why I get this error?
bug_odm
The command used:
docker run -ti --rm -v /media/matt/E721-22B4/mapping_datasets/test:/dataset opendronemap/odm --project-path /media/matt/E721-22B4/mapping_datasets test
Config:
Ubuntu 18.04 - ODM 2.0.0
Any help would be really appreciated.
Matt
Sorry to read you’re having trouble.
Are you able to update to a current build to start wtih?
Thks for your support, do you have a current build running on ubuntu 18.04?
Personally, no. I run Windows 11 and Alpine Linux.
I do know we have made many significant changes and fixes since V2.0.0, though.
Your docker command needs to be:
docker run -ti --rm -v /media/matt/E721-22B4/mapping_datasets/test:/datasets/test opendronemap/odm --project-path /datasets test
The paths need to refer to those mapped in the docker container, not the host system (it’s a bit confusing, I know).
Right, it was the point, the documentation is quite confusing though.
Thank you
Matt
Pull requests on documentation accepted! Glad it’s working for you now.
