Hi All,
I am currently doing some work on setting up command line ODM. I’ve been running via WebODM for quite some time, however when running the same commands via command line, the run time seems to be on the order of 4x as long. Both versions are running locally on the same machine. I suspect it may be a docker RAM or storage allocation?..although these seem to be working fine for WebODM…
Any thoughts would be greatly appreciated. Thank you in advance.
