I’m Korean and I’m writing a Google translator.
cpu 6600k
ram 16g
110 images
Code error 1 continues to occur.
There is no work result.
I’ve been successful with 40 images, but I’m not satisfied with the results, so I increased the number of files to 110.
코드 에러 1번이 계속 발생한다.
어떠한 작업 결과물도 없다.
40장의 이미지로는 성공한적이 있으나 결과가 만족스럽지 않아 110장으로 파일수를 늘렸다.
Help me
“Process exited with code 1” means that part of the processing failed. Sometimes it’s a problem with the dataset, sometimes it can be solved by tweaking the [Task Options](javascript:void(0) and sometimes it might be a bug! If you need help, upload your images somewhere like Dropbox or Google Drive and open a topic on our community forum, making sure to include a [copy of your task’s output](javascript:void(0);). Our awesome contributors will try to help you!
cost: 1.317500e+02, Termination: CONVERGENCE
2019-07-10 08:31:08,323 INFO: Adding DJI_0853.JPG to the reconstruction
2019-07-10 08:31:08,914 DEBUG: Local bundle sets: interior 30 boundary 15 other 0
2019-07-10 08:31:16,244 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.917270e+03, Final cost: 1.864704e+03, Termination: CONVERGENCE
2019-07-10 08:31:18,957 INFO: Removed outliers: 313
2019-07-10 08:31:19,083 INFO: -------------------------------------------------------
2019-07-10 08:31:19,297 INFO: DJI_0844.JPG resection inliers: 4379 / 4423
2019-07-10 08:31:19,461 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 4.490712e+02, Final cost: 1.024630e+02, Termination: CONVERGENCE
2019-07-10 08:31:19,463 INFO: Adding DJI_0844.JPG to the reconstruction
2019-07-10 08:31:20,737 DEBUG: Local bundle sets: interior 30 boundary 16 other 0
2019-07-10 08:31:28,848 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 1.815429e+03, Final cost: 1.769062e+03, Termination: CONVERGENCE
2019-07-10 08:31:32,054 INFO: Removed outliers: 296
2019-07-10 08:31:32,208 INFO: -------------------------------------------------------
2019-07-10 08:31:32,470 INFO: DJI_0873.JPG resection inliers: 4552 / 4594
2019-07-10 08:31:32,783 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 3.672519e+02, Final cost: 8.980310e+01, Termination: CONVERGENCE
2019-07-10 08:31:32,787 INFO: Adding DJI_0873.JPG to the reconstruction
2019-07-10 08:31:33,418 DEBUG: Local bundle sets: interior 30 boundary 17 other 0
2019-07-10 08:31:41,941 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.820087e+03, Final cost: 1.784393e+03, Termination: CONVERGENCE
2019-07-10 08:31:45,217 INFO: Removed outliers: 345
2019-07-10 08:31:45,388 INFO: -------------------------------------------------------
2019-07-10 08:31:45,642 INFO: DJI_0854.JPG resection inliers: 3965 / 4272
2019-07-10 08:31:45,816 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 3.874949e+02, Final cost: 9.632793e+01, Termination: CONVERGENCE
2019-07-10 08:31:45,828 INFO: Adding DJI_0854.JPG to the reconstruction
2019-07-10 08:31:46,504 DEBUG: Local bundle sets: interior 30 boundary 18 other 0
2019-07-10 08:31:58,177 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 1.905971e+03, Final cost: 1.869491e+03, Termination: CONVERGENCE
2019-07-10 08:32:01,589 INFO: Removed outliers: 267
2019-07-10 08:32:01,732 INFO: -------------------------------------------------------
2019-07-10 08:32:01,906 INFO: DJI_0861.JPG resection inliers: 3683 / 3722
2019-07-10 08:32:02,142 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.548594e+02, Final cost: 8.306019e+01, Termination: CONVERGENCE
2019-07-10 08:32:02,151 INFO: Adding DJI_0861.JPG to the reconstruction
2019-07-10 08:32:02,774 DEBUG: Local bundle sets: interior 30 boundary 19 other 0
2019-07-10 08:32:11,209 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.906259e+03, Final cost: 1.871917e+03, Termination: CONVERGENCE
2019-07-10 08:32:14,627 INFO: Removed outliers: 284
2019-07-10 08:32:14,770 INFO: -------------------------------------------------------
2019-07-10 08:32:14,961 INFO: DJI_0855.JPG resection inliers: 3696 / 3781
2019-07-10 08:32:15,129 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.291682e+02, Final cost: 9.959669e+01, Termination: CONVERGENCE
2019-07-10 08:32:15,134 INFO: Adding DJI_0855.JPG to the reconstruction
2019-07-10 08:32:15,348 INFO: Re-triangulating
2019-07-10 08:32:46,166 DEBUG: Ceres Solver Report: Iterations: 15, Initial cost: 2.361984e+03, Final cost: 2.309234e+03, Termination: CONVERGENCE
2019-07-10 08:33:24,276 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 3.893415e+03, Final cost: 3.818905e+03, Termination: CONVERGENCE
2019-07-10 08:33:27,823 INFO: Removed outliers: 9508
2019-07-10 08:33:28,505 INFO: -------------------------------------------------------
2019-07-10 08:33:28,710 INFO: DJI_0899.JPG resection inliers: 3658 / 3716
2019-07-10 08:33:28,876 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.164800e+02, Final cost: 1.104938e+02, Termination: CONVERGENCE
2019-07-10 08:33:28,882 INFO: Adding DJI_0899.JPG to the reconstruction
2019-07-10 08:33:29,431 DEBUG: Local bundle sets: interior 30 boundary 21 other 0
2019-07-10 08:33:36,516 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.132448e+03, Final cost: 1.987131e+03, Termination: CONVERGENCE
2019-07-10 08:33:39,413 INFO: Removed outliers: 1133
2019-07-10 08:33:39,534 INFO: -------------------------------------------------------
2019-07-10 08:33:39,746 INFO: DJI_0894.JPG resection inliers: 3762 / 3801
2019-07-10 08:33:39,923 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.292261e+02, Final cost: 1.135091e+02, Termination: CONVERGENCE
2019-07-10 08:33:39,926 INFO: Adding DJI_0894.JPG to the reconstruction
2019-07-10 08:33:40,465 DEBUG: Local bundle sets: interior 30 boundary 19 other 3
2019-07-10 08:33:48,057 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 1.968467e+03, Final cost: 1.919172e+03, Termination: CONVERGENCE
2019-07-10 08:33:51,216 INFO: Removed outliers: 459
2019-07-10 08:33:51,333 INFO: -------------------------------------------------------
2019-07-10 08:33:51,503 INFO: DJI_0843.JPG resection inliers: 3677 / 3706
2019-07-10 08:33:51,658 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.965651e+02, Final cost: 9.164099e+01, Termination: CONVERGENCE
2019-07-10 08:33:51,661 INFO: Adding DJI_0843.JPG to the reconstruction
2019-07-10 08:33:52,280 DEBUG: Local bundle sets: interior 30 boundary 22 other 1
2019-07-10 08:33:59,669 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.906144e+03, Final cost: 1.837013e+03, Termination: CONVERGENCE
2019-07-10 08:34:02,759 INFO: Removed outliers: 403
2019-07-10 08:34:02,890 INFO: -------------------------------------------------------
2019-07-10 08:34:03,096 INFO: DJI_0922.JPG resection inliers: 3298 / 3570
2019-07-10 08:34:03,319 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 5.370174e+02, Final cost: 1.291054e+02, Termination: CONVERGENCE
2019-07-10 08:34:03,327 INFO: Adding DJI_0922.JPG to the reconstruction
2019-07-10 08:34:03,935 DEBUG: Local bundle sets: interior 30 boundary 24 other 0
2019-07-10 08:34:12,006 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.227513e+03, Final cost: 2.181096e+03, Termination: CONVERGENCE
2019-07-10 08:34:15,138 INFO: Removed outliers: 272
2019-07-10 08:34:15,257 INFO: -------------------------------------------------------
2019-07-10 08:34:15,482 INFO: DJI_0923.JPG resection inliers: 3448 / 3696
2019-07-10 08:34:15,658 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 5.314116e+02, Final cost: 1.158927e+02, Termination: CONVERGENCE
2019-07-10 08:34:15,661 INFO: Adding DJI_0923.JPG to the reconstruction
2019-07-10 08:34:16,497 DEBUG: Local bundle sets: interior 30 boundary 25 other 0
2019-07-10 08:34:25,112 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.352682e+03, Final cost: 2.304762e+03, Termination: CONVERGENCE
2019-07-10 08:34:28,413 INFO: Removed outliers: 310
2019-07-10 08:34:28,521 INFO: -------------------------------------------------------
2019-07-10 08:34:28,744 INFO: DJI_0921.JPG resection inliers: 4960 / 5031
2019-07-10 08:34:28,941 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 5.495420e+02, Final cost: 1.367201e+02, Termination: CONVERGENCE
2019-07-10 08:34:28,943 INFO: Adding DJI_0921.JPG to the reconstruction
2019-07-10 08:34:29,636 DEBUG: Local bundle sets: interior 30 boundary 26 other 0
2019-07-10 08:34:37,731 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.219749e+03, Final cost: 2.167742e+03, Termination: CONVERGENCE
2019-07-10 08:34:41,096 INFO: Removed outliers: 341
2019-07-10 08:34:41,218 INFO: -------------------------------------------------------
2019-07-10 08:34:41,436 INFO: DJI_0924.JPG resection inliers: 4552 / 5091
2019-07-10 08:34:41,621 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 8.063763e+02, Final cost: 1.266538e+02, Termination: CONVERGENCE
2019-07-10 08:34:41,626 INFO: Adding DJI_0924.JPG to the reconstruction
2019-07-10 08:34:42,970 DEBUG: Local bundle sets: interior 30 boundary 27 other 0
2019-07-10 08:34:51,805 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.442902e+03, Final cost: 2.396274e+03, Termination: CONVERGENCE
2019-07-10 08:34:55,271 INFO: Removed outliers: 326
2019-07-10 08:34:55,379 INFO: -------------------------------------------------------
2019-07-10 08:34:55,588 INFO: DJI_0920.JPG resection inliers: 4907 / 4978
2019-07-10 08:34:55,848 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 4.570272e+02, Final cost: 1.356187e+02, Termination: CONVERGENCE
2019-07-10 08:34:55,850 INFO: Adding DJI_0920.JPG to the reconstruction
2019-07-10 08:34:56,537 DEBUG: Local bundle sets: interior 30 boundary 27 other 1
2019-07-10 08:35:04,595 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.098656e+03, Final cost: 2.042458e+03, Termination: CONVERGENCE
2019-07-10 08:35:08,079 INFO: Removed outliers: 319
2019-07-10 08:35:08,209 INFO: -------------------------------------------------------
2019-07-10 08:35:08,453 INFO: DJI_0925.JPG resection inliers: 4344 / 4909
2019-07-10 08:35:08,658 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 9.231036e+02, Final cost: 1.403026e+02, Termination: CONVERGENCE
2019-07-10 08:35:08,660 INFO: Adding DJI_0925.JPG to the reconstruction
2019-07-10 08:35:09,168 DEBUG: Local bundle sets: interior 30 boundary 29 other 0
2019-07-10 08:35:18,161 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.513239e+03, Final cost: 2.458625e+03, Termination: CONVERGENCE
2019-07-10 08:35:21,747 INFO: Removed outliers: 348
2019-07-10 08:35:21,858 INFO: -------------------------------------------------------
2019-07-10 08:35:22,157 INFO: DJI_0926.JPG resection inliers: 4919 / 5018
2019-07-10 08:35:22,473 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.720831e+02, Final cost: 1.537140e+02, Termination: CONVERGENCE
2019-07-10 08:35:22,479 INFO: Adding DJI_0926.JPG to the reconstruction
2019-07-10 08:35:23,054 DEBUG: Local bundle sets: interior 30 boundary 30 other 0
2019-07-10 08:35:31,881 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.501213e+03, Final cost: 2.443125e+03, Termination: CONVERGENCE
2019-07-10 08:35:35,626 INFO: Removed outliers: 408
2019-07-10 08:35:35,725 INFO: -------------------------------------------------------
2019-07-10 08:35:35,967 INFO: DJI_0927.JPG resection inliers: 4751 / 4856
2019-07-10 08:35:36,198 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 4.944338e+02, Final cost: 1.551574e+02, Termination: CONVERGENCE
2019-07-10 08:35:36,203 INFO: Adding DJI_0927.JPG to the reconstruction
2019-07-10 08:35:36,439 INFO: Re-triangulating
2019-07-10 08:36:06,789 DEBUG: Ceres Solver Report: Iterations: 14, Initial cost: 3.048966e+03, Final cost: 2.991111e+03, Termination: CONVERGENCE
2019-07-10 08:36:49,206 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 5.016794e+03, Final cost: 4.920594e+03, Termination: CONVERGENCE
2019-07-10 08:36:52,576 INFO: Removed outliers: 11600
2019-07-10 08:36:53,531 INFO: -------------------------------------------------------
2019-07-10 08:36:54,002 INFO: DJI_0928.JPG resection inliers: 4230 / 4424
2019-07-10 08:36:54,169 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 9.225961e+02, Final cost: 1.597489e+02, Termination: CONVERGENCE
2019-07-10 08:36:54,172 INFO: Adding DJI_0928.JPG to the reconstruction
2019-07-10 08:36:54,803 DEBUG: Local bundle sets: interior 30 boundary 31 other 1
2019-07-10 08:37:02,102 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.667092e+03, Final cost: 2.482418e+03, Termination: CONVERGENCE
2019-07-10 08:37:05,537 INFO: Removed outliers: 1396
2019-07-10 08:37:05,633 INFO: -------------------------------------------------------
2019-07-10 08:37:05,993 INFO: DJI_0919.JPG resection inliers: 4274 / 4311
2019-07-10 08:37:08,284 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.482541e+02, Final cost: 9.910278e+01, Termination: CONVERGENCE
2019-07-10 08:37:08,288 INFO: Adding DJI_0919.JPG to the reconstruction
2019-07-10 08:37:08,967 DEBUG: Local bundle sets: interior 30 boundary 30 other 3
2019-07-10 08:37:17,243 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.323217e+03, Final cost: 2.238875e+03, Termination: CONVERGENCE
2019-07-10 08:37:20,528 INFO: Removed outliers: 593
2019-07-10 08:37:20,620 INFO: -------------------------------------------------------
2019-07-10 08:37:20,824 INFO: DJI_0929.JPG resection inliers: 4196 / 4283
2019-07-10 08:37:20,998 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.939995e+02, Final cost: 1.400724e+02, Termination: CONVERGENCE
2019-07-10 08:37:20,999 INFO: Adding DJI_0929.JPG to the reconstruction
2019-07-10 08:37:21,596 DEBUG: Local bundle sets: interior 30 boundary 33 other 1
2019-07-10 08:37:29,323 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.456613e+03, Final cost: 2.401869e+03, Termination: CONVERGENCE
2019-07-10 08:37:33,104 INFO: Removed outliers: 560
2019-07-10 08:37:33,204 INFO: -------------------------------------------------------
2019-07-10 08:37:33,371 INFO: DJI_0930.JPG resection inliers: 3498 / 3696
2019-07-10 08:37:33,591 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 5.406194e+02, Final cost: 1.283589e+02, Termination: CONVERGENCE
2019-07-10 08:37:33,595 INFO: Adding DJI_0930.JPG to the reconstruction
2019-07-10 08:37:34,207 DEBUG: Local bundle sets: interior 30 boundary 30 other 5
2019-07-10 08:37:43,459 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 2.361506e+03, Final cost: 2.304386e+03, Termination: CONVERGENCE
2019-07-10 08:37:46,745 INFO: Removed outliers: 464
2019-07-10 08:37:46,831 INFO: -------------------------------------------------------
2019-07-10 08:37:47,024 INFO: DJI_0874.JPG resection inliers: 3332 / 3448
2019-07-10 08:37:47,169 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 5.618734e+02, Final cost: 8.139466e+01, Termination: CONVERGENCE
2019-07-10 08:37:47,173 INFO: Adding DJI_0874.JPG to the reconstruction
2019-07-10 08:37:47,820 DEBUG: Local bundle sets: interior 30 boundary 28 other 8
2019-07-10 08:37:56,587 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.055766e+03, Final cost: 2.021085e+03, Termination: CONVERGENCE
2019-07-10 08:38:00,091 INFO: Removed outliers: 305
2019-07-10 08:38:00,160 INFO: -------------------------------------------------------
2019-07-10 08:38:00,304 INFO: DJI_0898.JPG resection inliers: 2943 / 3444
2019-07-10 08:38:00,471 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 6.803227e+02, Final cost: 1.029437e+02, Termination: CONVERGENCE
2019-07-10 08:38:00,475 INFO: Adding DJI_0898.JPG to the reconstruction
2019-07-10 08:38:01,000 DEBUG: Local bundle sets: interior 30 boundary 25 other 12
2019-07-10 08:38:08,360 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.194307e+03, Final cost: 2.151945e+03, Termination: CONVERGENCE
2019-07-10 08:38:11,940 INFO: Removed outliers: 457
2019-07-10 08:38:12,027 INFO: -------------------------------------------------------
2019-07-10 08:38:12,203 INFO: DJI_0880.JPG resection inliers: 3378 / 3420
2019-07-10 08:38:12,373 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.505324e+02, Final cost: 8.422189e+01, Termination: CONVERGENCE
2019-07-10 08:38:12,377 INFO: Adding DJI_0880.JPG to the reconstruction
2019-07-10 08:38:13,139 DEBUG: Local bundle sets: interior 30 boundary 26 other 12
2019-07-10 08:38:21,041 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.011850e+03, Final cost: 1.979922e+03, Termination: CONVERGENCE
2019-07-10 08:38:24,683 INFO: Removed outliers: 296
2019-07-10 08:38:24,756 INFO: -------------------------------------------------------
2019-07-10 08:38:24,980 INFO: DJI_0912.JPG resection inliers: 3383 / 3432
2019-07-10 08:38:25,127 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 1.967362e+02, Final cost: 1.201743e+02, Termination: CONVERGENCE
2019-07-10 08:38:25,131 INFO: Adding DJI_0912.JPG to the reconstruction
2019-07-10 08:38:27,213 DEBUG: Local bundle sets: interior 30 boundary 27 other 12
2019-07-10 08:38:35,486 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.037551e+03, Final cost: 1.989276e+03, Termination: CONVERGENCE
2019-07-10 08:38:39,713 INFO: Removed outliers: 468
2019-07-10 08:38:39,813 INFO: -------------------------------------------------------
2019-07-10 08:38:40,052 INFO: DJI_0931.JPG resection inliers: 3248 / 3368
2019-07-10 08:38:40,261 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.713650e+02, Final cost: 1.342903e+02, Termination: CONVERGENCE
2019-07-10 08:38:40,263 INFO: Adding DJI_0931.JPG to the reconstruction
2019-07-10 08:38:40,960 DEBUG: Local bundle sets: interior 30 boundary 28 other 12
2019-07-10 08:38:48,827 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.334241e+03, Final cost: 2.274923e+03, Termination: CONVERGENCE
2019-07-10 08:38:52,446 INFO: Removed outliers: 400
2019-07-10 08:38:52,512 INFO: -------------------------------------------------------
2019-07-10 08:38:52,672 INFO: DJI_0860.JPG resection inliers: 3277 / 3325
2019-07-10 08:38:52,862 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.857609e+02, Final cost: 1.179166e+02, Termination: CONVERGENCE
2019-07-10 08:38:52,866 INFO: Adding DJI_0860.JPG to the reconstruction
2019-07-10 08:38:53,505 DEBUG: Local bundle sets: interior 30 boundary 24 other 17
2019-07-10 08:39:03,345 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 2.168475e+03, Final cost: 2.115703e+03, Termination: CONVERGENCE
2019-07-10 08:39:07,652 INFO: Removed outliers: 330
2019-07-10 08:39:07,732 INFO: -------------------------------------------------------
2019-07-10 08:39:08,087 INFO: DJI_0856.JPG resection inliers: 3455 / 3494
2019-07-10 08:39:08,245 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.260410e+02, Final cost: 1.189221e+02, Termination: CONVERGENCE
2019-07-10 08:39:08,249 INFO: Adding DJI_0856.JPG to the reconstruction
2019-07-10 08:39:08,847 DEBUG: Local bundle sets: interior 30 boundary 30 other 12
2019-07-10 08:39:16,472 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.380767e+03, Final cost: 2.326377e+03, Termination: CONVERGENCE
2019-07-10 08:39:20,240 INFO: Removed outliers: 319
2019-07-10 08:39:20,312 INFO: -------------------------------------------------------
2019-07-10 08:39:20,544 INFO: DJI_0895.JPG resection inliers: 3135 / 3217
2019-07-10 08:39:20,699 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.556357e+02, Final cost: 1.276605e+02, Termination: CONVERGENCE
2019-07-10 08:39:20,701 INFO: Adding DJI_0895.JPG to the reconstruction
2019-07-10 08:39:21,221 DEBUG: Local bundle sets: interior 30 boundary 25 other 18
2019-07-10 08:39:29,937 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 2.143791e+03, Final cost: 2.096488e+03, Termination: CONVERGENCE
2019-07-10 08:39:33,936 INFO: Removed outliers: 409
2019-07-10 08:39:34,000 INFO: -------------------------------------------------------
2019-07-10 08:39:34,397 INFO: DJI_0842.JPG resection inliers: 3058 / 3089
2019-07-10 08:39:34,518 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.428487e+02, Final cost: 9.529984e+01, Termination: CONVERGENCE
2019-07-10 08:39:34,519 INFO: Adding DJI_0842.JPG to the reconstruction
2019-07-10 08:39:35,091 INFO: Re-triangulating
2019-07-10 08:40:04,909 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 3.730596e+03, Final cost: 3.683232e+03, Termination: CONVERGENCE
2019-07-10 08:41:12,468 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 6.320074e+03, Final cost: 6.196438e+03, Termination: CONVERGENCE
2019-07-10 08:41:24,775 INFO: Removed outliers: 14807
2019-07-10 08:41:25,999 INFO: -------------------------------------------------------
2019-07-10 08:41:26,170 INFO: DJI_0875.JPG resection inliers: 2782 / 2987
2019-07-10 08:41:26,347 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 6.722257e+02, Final cost: 9.356579e+01, Termination: CONVERGENCE
2019-07-10 08:41:26,353 INFO: Adding DJI_0875.JPG to the reconstruction
2019-07-10 08:41:26,991 DEBUG: Local bundle sets: interior 30 boundary 26 other 19
2019-07-10 08:41:36,417 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.194108e+03, Final cost: 2.050810e+03, Termination: CONVERGENCE
2019-07-10 08:41:40,160 INFO: Removed outliers: 1496
2019-07-10 08:41:40,218 INFO: -------------------------------------------------------
2019-07-10 08:41:40,410 INFO: DJI_0932.JPG resection inliers: 2650 / 2817
2019-07-10 08:41:40,522 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 6.451643e+02, Final cost: 1.033333e+02, Termination: CONVERGENCE
2019-07-10 08:41:40,530 INFO: Adding DJI_0932.JPG to the reconstruction
2019-07-10 08:41:41,243 DEBUG: Local bundle sets: interior 30 boundary 30 other 16
2019-07-10 08:41:49,566 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 2.470892e+03, Final cost: 2.309833e+03, Termination: CONVERGENCE
2019-07-10 08:41:53,743 INFO: Removed outliers: 961
2019-07-10 08:41:53,818 INFO: -------------------------------------------------------
2019-07-10 08:41:53,954 INFO: DJI_0933.JPG resection inliers: 2934 / 3005
2019-07-10 08:41:54,061 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.356147e+02, Final cost: 1.749599e+02, Termination: CONVERGENCE
2019-07-10 08:41:54,067 INFO: Adding DJI_0933.JPG to the reconstruction
2019-07-10 08:41:54,732 DEBUG: Local bundle sets: interior 30 boundary 27 other 20
2019-07-10 08:42:02,411 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.316916e+03, Final cost: 2.236111e+03, Termination: CONVERGENCE
2019-07-10 08:42:06,250 INFO: Removed outliers: 541
2019-07-10 08:42:06,302 INFO: -------------------------------------------------------
2019-07-10 08:42:06,440 INFO: DJI_0841.JPG resection inliers: 2774 / 2815
2019-07-10 08:42:06,573 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.119370e+02, Final cost: 9.607638e+01, Termination: CONVERGENCE
2019-07-10 08:42:06,575 INFO: Adding DJI_0841.JPG to the reconstruction
2019-07-10 08:42:07,161 DEBUG: Local bundle sets: interior 30 boundary 27 other 21
2019-07-10 08:42:13,770 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.037245e+03, Final cost: 1.986073e+03, Termination: CONVERGENCE
2019-07-10 08:42:18,107 INFO: Removed outliers: 322
2019-07-10 08:42:18,198 INFO: -------------------------------------------------------
2019-07-10 08:42:18,437 INFO: DJI_0827.JPG resection inliers: 2480 / 2590
2019-07-10 08:42:18,555 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.744188e+02, Final cost: 1.203228e+02, Termination: CONVERGENCE
2019-07-10 08:42:18,558 INFO: Adding DJI_0827.JPG to the reconstruction
2019-07-10 08:42:19,372 DEBUG: Local bundle sets: interior 30 boundary 47 other 2
2019-07-10 08:42:28,994 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.764296e+03, Final cost: 2.708959e+03, Termination: CONVERGENCE
2019-07-10 08:42:32,996 INFO: Removed outliers: 288
2019-07-10 08:42:33,069 INFO: -------------------------------------------------------
2019-07-10 08:42:33,407 INFO: DJI_0826.JPG resection inliers: 2678 / 2738
2019-07-10 08:42:33,601 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.063137e+02, Final cost: 9.700302e+01, Termination: CONVERGENCE
2019-07-10 08:42:33,604 INFO: Adding DJI_0826.JPG to the reconstruction
2019-07-10 08:42:40,457 DEBUG: Local bundle sets: interior 30 boundary 44 other 6
2019-07-10 08:42:50,954 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.563007e+03, Final cost: 2.532219e+03, Termination: CONVERGENCE
2019-07-10 08:42:55,104 INFO: Removed outliers: 238
2019-07-10 08:42:55,229 INFO: -------------------------------------------------------
2019-07-10 08:42:55,674 INFO: DJI_0828.JPG resection inliers: 3502 / 3609
2019-07-10 08:42:55,841 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.318906e+02, Final cost: 1.410240e+02, Termination: CONVERGENCE
2019-07-10 08:42:55,848 INFO: Adding DJI_0828.JPG to the reconstruction
2019-07-10 08:42:56,340 DEBUG: Local bundle sets: interior 30 boundary 50 other 1
2019-07-10 08:43:05,687 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.831774e+03, Final cost: 2.772578e+03, Termination: CONVERGENCE
2019-07-10 08:43:10,422 INFO: Removed outliers: 299
2019-07-10 08:43:10,491 INFO: -------------------------------------------------------
2019-07-10 08:43:10,935 INFO: DJI_0825.JPG resection inliers: 3589 / 3672
2019-07-10 08:43:11,084 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 4.547045e+02, Final cost: 1.119958e+02, Termination: CONVERGENCE
2019-07-10 08:43:11,089 INFO: Adding DJI_0825.JPG to the reconstruction
2019-07-10 08:43:11,779 DEBUG: Local bundle sets: interior 30 boundary 42 other 10
2019-07-10 08:43:19,215 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.517781e+03, Final cost: 2.473421e+03, Termination: CONVERGENCE
2019-07-10 08:43:23,398 INFO: Removed outliers: 194
2019-07-10 08:43:23,461 INFO: -------------------------------------------------------
2019-07-10 08:43:23,631 INFO: DJI_0829.JPG resection inliers: 3265 / 3359
2019-07-10 08:43:23,762 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.023819e+02, Final cost: 1.322306e+02, Termination: CONVERGENCE
2019-07-10 08:43:23,767 INFO: Adding DJI_0829.JPG to the reconstruction
2019-07-10 08:43:24,327 DEBUG: Local bundle sets: interior 30 boundary 53 other 0
2019-07-10 08:43:34,589 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.880769e+03, Final cost: 2.829188e+03, Termination: CONVERGENCE
2019-07-10 08:43:39,038 INFO: Removed outliers: 320
2019-07-10 08:43:39,085 INFO: -------------------------------------------------------
2019-07-10 08:43:39,259 INFO: DJI_0824.JPG resection inliers: 3106 / 3234
2019-07-10 08:43:39,420 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.803771e+02, Final cost: 1.025488e+02, Termination: CONVERGENCE
2019-07-10 08:43:39,425 INFO: Adding DJI_0824.JPG to the reconstruction
2019-07-10 08:43:40,102 DEBUG: Local bundle sets: interior 30 boundary 44 other 10
2019-07-10 08:43:48,083 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.525177e+03, Final cost: 2.482528e+03, Termination: CONVERGENCE
2019-07-10 08:43:52,967 INFO: Removed outliers: 199
2019-07-10 08:43:53,029 INFO: -------------------------------------------------------
2019-07-10 08:43:53,279 INFO: DJI_0830.JPG resection inliers: 2976 / 3070
2019-07-10 08:43:53,462 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.917216e+02, Final cost: 1.338014e+02, Termination: CONVERGENCE
2019-07-10 08:43:53,472 INFO: Adding DJI_0830.JPG to the reconstruction
2019-07-10 08:43:53,988 DEBUG: Local bundle sets: interior 30 boundary 54 other 1
2019-07-10 08:44:04,096 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.914620e+03, Final cost: 2.862266e+03, Termination: CONVERGENCE
2019-07-10 08:44:08,557 INFO: Removed outliers: 254
2019-07-10 08:44:08,607 INFO: -------------------------------------------------------
2019-07-10 08:44:08,868 INFO: DJI_0823.JPG resection inliers: 2672 / 2786
2019-07-10 08:44:09,005 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 5.469461e+02, Final cost: 1.052590e+02, Termination: CONVERGENCE
2019-07-10 08:44:09,008 INFO: Adding DJI_0823.JPG to the reconstruction
2019-07-10 08:44:09,727 DEBUG: Local bundle sets: interior 30 boundary 41 other 15
2019-07-10 08:44:18,593 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.582635e+03, Final cost: 2.532300e+03, Termination: CONVERGENCE
2019-07-10 08:44:23,287 INFO: Removed outliers: 246
2019-07-10 08:44:23,333 INFO: -------------------------------------------------------
2019-07-10 08:44:23,530 INFO: DJI_0831.JPG resection inliers: 2581 / 2678
2019-07-10 08:44:23,652 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.747553e+02, Final cost: 1.193716e+02, Termination: CONVERGENCE
2019-07-10 08:44:23,656 INFO: Adding DJI_0831.JPG to the reconstruction
2019-07-10 08:44:24,163 DEBUG: Local bundle sets: interior 30 boundary 55 other 2
2019-07-10 08:44:33,735 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.824943e+03, Final cost: 2.780597e+03, Termination: CONVERGENCE
2019-07-10 08:44:38,836 INFO: Removed outliers: 253
2019-07-10 08:44:38,896 INFO: -------------------------------------------------------
2019-07-10 08:44:39,391 INFO: DJI_0832.JPG resection inliers: 2582 / 2715
2019-07-10 08:45:02,836 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.894241e+02, Final cost: 1.244646e+02, Termination: CONVERGENCE
2019-07-10 08:45:02,868 INFO: Adding DJI_0832.JPG to the reconstruction
2019-07-10 08:45:05,914 DEBUG: Local bundle sets: interior 30 boundary 50 other 8
2019-07-10 08:45:29,884 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 2.621967e+03, Final cost: 2.574839e+03, Termination: CONVERGENCE
2019-07-10 08:45:35,641 INFO: Removed outliers: 261
2019-07-10 08:45:36,117 INFO: -------------------------------------------------------
2019-07-10 08:45:36,469 INFO: DJI_0833.JPG resection inliers: 2543 / 2784
2019-07-10 08:45:36,588 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.798961e+02, Final cost: 1.113287e+02, Termination: CONVERGENCE
2019-07-10 08:45:36,593 INFO: Adding DJI_0833.JPG to the reconstruction
2019-07-10 08:45:37,056 INFO: Re-triangulating
Killed
File “/code/run.py”, line 56, in
app.execute()
File “/code/stages/odm_app.py”, line 93, in execute
File “/code/opendm/types.py”, line 376, in run
File “/code/opendm/types.py”, line 357, in run
File “/code/stages/run_opensfm.py”, line 29, in process
octx.reconstruct(self.rerun())
File “/code/opendm/osfm.py”, line 47, in reconstruct
self.run(‘reconstruct’)
File “/code/opendm/osfm.py”, line 21, in run
Exception: Child returned 137
