Good day, I was trying to WebODM and I got 3 times, the Code 1 error so following instructions I uploaded my pictures to: https://photos.app.goo.gl/x5YqsZ9MvYjYexym9 and the copy of the task is:
[INFO] Initializing OpenDroneMap app - Thu Feb 07 16:19:54 2019
[DEBUG] Loading dataset from: /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/images
[DEBUG] /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/images
[WARNING] Could not find ccd_width in file. Use --force-ccd or edit the sensor_data.json file to manually input ccd width
[DEBUG] Loaded DJI_0109.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0261111111 | lon: -89.7833333333 | alt: 10.0
[DEBUG] Loaded DJI_0091.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0100.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 11.0
[DEBUG] Loaded DJI_0115.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 10.0
[DEBUG] Loaded DJI_0092.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0097.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0095.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0093.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0088.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.8
[DEBUG] Loaded DJI_0106.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 10.6
[DEBUG] Loaded DJI_0090.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0101.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 11.0
[DEBUG] Loaded DJI_0118.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 13.9
[DEBUG] Loaded DJI_0121.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 15.1
[DEBUG] Loaded DJI_0122.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 15.1
[DEBUG] Loaded DJI_0089.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0116.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 10.0
[DEBUG] Loaded DJI_0120.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 15.1
[DEBUG] Loaded DJI_0098.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 11.8
[DEBUG] Loaded DJI_0096.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0105.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 10.6
[DEBUG] Loaded DJI_0113.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 9.9
[DEBUG] Loaded DJI_0119.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 15.1
[DEBUG] Loaded DJI_0112.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0261111111 | lon: -89.7833333333 | alt: 10.0
[DEBUG] Loaded DJI_0117.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 10.0
[DEBUG] Loaded DJI_0099.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7836111111 | alt: 13.4
[DEBUG] Loaded DJI_0107.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 10.6
[DEBUG] Loaded DJI_0108.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0261111111 | lon: -89.7836111111 | alt: 9.9
[DEBUG] Loaded DJI_0094.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0266666667 | lon: -89.7836111111 | alt: 11.7
[DEBUG] Loaded DJI_0114.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0263888889 | lon: -89.7833333333 | alt: 10.0
[DEBUG] Loaded DJI_0111.JPG | camera: dji fc1102 | dimensions: 2048 x 1536 | focal: 4.49 | ccd: None | lat: 14.0261111111 | lon: -89.7833333333 | alt: 10.0
[INFO] Wrote images database: /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/images.json
[INFO] Found 31 usable images
[DEBUG] running /code/build/bin/odm_extract_utm -imagesPath /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/images/ -imageListFile /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/img_list.txt -outputCoordFile /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/odm_georeferencing/coords.txt -logFile /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/odm_georeferencing/odm_georeferencing_utm_log.txt
Warning: Directory Photo has an unexpected next pointer; ignored.
Warning: Directory Iop has an unexpected next pointer; ignored.
Warning: Directory GPSInfo has an unexpected next pointer; ignored.
[INFO] Running ODM Load Dataset Cell - Finished.
[DEBUG] Altitude data detected, enabling it for GPS alignment
[DEBUG] [‘use_exif_size: no’, ‘feature_process_size: 2048’, ‘feature_min_frames: 1600’, ‘processes: 2’, ‘matching_gps_neighbors: 8’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 1000.0’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘use_altitude_tag: True’, ‘align_method: naive’]
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/opensfm
2019-02-07 16:19:58,019 INFO: Loading existing EXIF for DJI_0109.JPG
2019-02-07 16:19:58,019 INFO: Loading existing EXIF for DJI_0091.JPG
2019-02-07 16:19:58,020 INFO: Loading existing EXIF for DJI_0100.JPG
2019-02-07 16:19:58,020 INFO: Loading existing EXIF for DJI_0115.JPG
2019-02-07 16:19:58,021 INFO: Loading existing EXIF for DJI_0092.JPG
2019-02-07 16:19:58,021 INFO: Loading existing EXIF for DJI_0097.JPG
2019-02-07 16:19:58,021 INFO: Loading existing EXIF for DJI_0095.JPG
2019-02-07 16:19:58,022 INFO: Loading existing EXIF for DJI_0093.JPG
2019-02-07 16:19:58,022 INFO: Loading existing EXIF for DJI_0088.JPG
2019-02-07 16:19:58,023 INFO: Loading existing EXIF for DJI_0106.JPG
2019-02-07 16:19:58,023 INFO: Loading existing EXIF for DJI_0090.JPG
2019-02-07 16:19:58,024 INFO: Loading existing EXIF for DJI_0101.JPG
2019-02-07 16:19:58,024 INFO: Loading existing EXIF for DJI_0118.JPG
2019-02-07 16:19:58,025 INFO: Loading existing EXIF for DJI_0121.JPG
2019-02-07 16:19:58,025 INFO: Loading existing EXIF for DJI_0122.JPG
2019-02-07 16:19:58,026 INFO: Loading existing EXIF for DJI_0089.JPG
2019-02-07 16:19:58,027 INFO: Loading existing EXIF for DJI_0116.JPG
2019-02-07 16:19:58,027 INFO: Loading existing EXIF for DJI_0120.JPG
2019-02-07 16:19:58,028 INFO: Loading existing EXIF for DJI_0098.JPG
2019-02-07 16:19:58,028 INFO: Loading existing EXIF for DJI_0096.JPG
2019-02-07 16:19:58,029 INFO: Loading existing EXIF for DJI_0105.JPG
2019-02-07 16:19:58,030 INFO: Loading existing EXIF for DJI_0113.JPG
2019-02-07 16:19:58,030 INFO: Loading existing EXIF for DJI_0119.JPG
2019-02-07 16:19:58,031 INFO: Loading existing EXIF for DJI_0112.JPG
2019-02-07 16:19:58,031 INFO: Loading existing EXIF for DJI_0117.JPG
2019-02-07 16:19:58,032 INFO: Loading existing EXIF for DJI_0099.JPG
2019-02-07 16:19:58,032 INFO: Loading existing EXIF for DJI_0107.JPG
2019-02-07 16:19:58,032 INFO: Loading existing EXIF for DJI_0108.JPG
2019-02-07 16:19:58,033 INFO: Loading existing EXIF for DJI_0094.JPG
2019-02-07 16:19:58,033 INFO: Loading existing EXIF for DJI_0114.JPG
2019-02-07 16:19:58,033 INFO: Loading existing EXIF for DJI_0111.JPG
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm detect_features /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/opensfm
2019-02-07 16:19:59,310 INFO: Extracting ROOT_HAHOG features for image DJI_0109.JPG
2019-02-07 16:19:59,710 INFO: Extracting ROOT_HAHOG features for image DJI_0091.JPG
2019-02-07 16:19:59,710 INFO: Extracting ROOT_HAHOG features for image DJI_0100.JPG
2019-02-07 16:19:59,711 INFO: Extracting ROOT_HAHOG features for image DJI_0115.JPG
2019-02-07 16:19:59,712 INFO: Extracting ROOT_HAHOG features for image
2019-02-07 16:19:59,787 INFO: Extracting ROOT_HAHOG features for image DJI_0117.JPG
2019-02-07 16:19:59,791 INFO: Extracting ROOT_HAHOG features for image DJI_0099.JPG
2019-02-07 16:19:59,797 INFO: Extracting ROOT_HAHOG features for image DJI_0107.JPG
2019-02-07 16:19:59,801 INFO: Extracting ROOT_HAHOG features for image DJI_0108.JPG
2019-02-07 16:19:59,807 INFO: Extracting ROOT_HAHOG features for image DJI_0094.JPG
2019-02-07 16:19:59,812 INFO: Extracting ROOT_HAHOG features for image DJI_0114.JPG
2019-02-07 16:19:59,817 INFO: Extracting ROOT_HAHOG features for image DJI_0111.JPG
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm match_features /var/www/data/ba565eaf-53e8-433f-aeec-be8ccd2b6452/opensfm
2019-02-07 16:20:00,549 INFO: Matching 158 image pairs
2019-02-07 16:20:01,192 INFO: Matching DJI_0105.JPG - 1 / 31
2019-02-07 16:20:01,759 INFO: Matching DJI_0089.JPG - 2 / 31
2019-02-07 16:20:05,470 DEBUG: DJI_0105.JPG - DJI_0114.JPG has 118 candidate matches
2019-02-07 16:20:05,471 DEBUG: Robust matching time : 0.000847816467285s
2019-02-07 16:20:05,471 DEBUG: Full matching 98 / 118, time: 4.27937889099s
2019-02-07 16:20:06,374 DEBUG: DJI_0089.JPG - DJI_0093.JPG has 372 candidate matches
2019-02-07 16:20:06,377 DEBUG: Robust matching time : 0.00232195854187s
2019-02-07 16:20:06,377 DEBUG: Full matching 292 / 372, time: 4.61768102646s
2019-02-07 16:20:09,384 DEBUG: DJI_0105.JPG - DJI_0116.JPG has 13 candidate matches
2019-02-07 16:20:10,542 DEBUG: DJI_0089.JPG - DJI_0092.JPG has 529 candidate matches
2019-02-07 16:20:10,544 DEBUG: Robust matching time : 0.00146007537842s
2019-02-07 16:20:10,544 DEBUG: Full matching 429 / 529, time: 4.1665430069s
2019-02-07 16:20:13,460 DEBUG: DJI_0105.JPG - DJI_0113.JPG has 173 candidate matches
2019-02-07 16:20:13,461 DEBUG: Robust matching time : 0.000699043273926s
2019-02-07 16:20:13,462 DEBUG: Full matching 145 / 173, time: 4.07740616798s
2019-02-07 16:20:14,677 DEBUG: DJI_0089.JPG - DJI_0095.JPG has 115 candidate
2019-02-07 16:23:15,330 DEBUG: Full matching 32 / 58, time: 4.51850008965s
2019-02-07 16:23:16,304 DEBUG: DJI_0096.JPG - DJI_0119.JPG has 59 candidate matches
