date matches
2018-10-13 21:47:25,862 DEBUG: 20181013_214650.jpg - 20181013_214656.jpg has 30 candidate matches
2018-10-13 21:47:26,435 DEBUG: 20181013_214651.jpg - 20181013_214708.jpg has 30 candidate matches
2018-10-13 21:47:27,158 DEBUG: 20181013_214537.jpg - 20181013_2146400.jpg has 25 candidate matches
2018-10-13 21:47:27,183 DEBUG: 20181013_214650.jpg - 20181013_2146520.jpg has 84 candidate matches
2018-10-13 21:47:27,189 DEBUG: Robust matching time : 0.00535798072815s
2018-10-13 21:47:27,189 DEBUG: Full matching 21 / 84, time: 1.325922966s
2018-10-13 21:47:27,728 DEBUG: 20181013_214651.jpg - 20181013_214658.jpg has 14 candidate matches
2018-10-13 21:47:28,408 DEBUG: 20181013_214650.jpg - 20181013_2147090.jpg has 25 candidate matches
2018-10-13 21:47:28,951 DEBUG: 20181013_214651.jpg - 20181013_2147070.jpg has 24 candidate matches
2018-10-13 21:47:29,693 DEBUG: 20181013_214650.jpg - 20181013_214708.jpg has 19 candidate matches
2018-10-13 21:47:30,206 DEBUG: 20181013_214651.jpg - 20181013_214656.jpg has 29 candidate matches
2018-10-13 21:47:30,927 DEBUG: 20181013_214650.jpg - 20181013_2146510.jpg has 193 candidate matches
2018-10-13 21:47:30,934 DEBUG: Robust matching time : 0.00693702697754s
2018-10-13 21:47:30,934 DEBUG: Full matching 107 / 193, time: 1.24071598053s
2018-10-13 21:47:31,514 DEBUG: 20181013_214651.jpg - 20181013_214706.jpg has 29 candidate matches
2018-10-13 21:47:32,142 DEBUG: 20181013_214650.jpg - 20181013_2147060.jpg has 27 candidate matches
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm create_tracks /var/www/data/49f9b1e8-13b1-4589-bb36-988e1f22599f/opensfm
2018-10-13 21:47:32,654 INFO: reading features
2018-10-13 21:47:34,822 DEBUG: Merging features onto tracks
2018-10-13 21:47:35,085 DEBUG: Good tracks: 10101
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm reconstruct /var/www/data/49f9b1e8-13b1-4589-bb36-988e1f22599f/opensfm
2018-10-13 21:47:36,134 INFO: Starting incremental reconstruction
2018-10-13 21:47:38,040 INFO: Starting reconstruction with 20181013_214540.jpg and 20181013_214542.jpg
2018-10-13 21:47:38,167 INFO: Two-view reconstruction inliers: 919 / 923
2018-10-13 21:47:38,237 INFO: Triangulated: 921
2018-10-13 21:47:38,310 DEBUG: Ceres Solver Report: Iterations: 2, Initial cost: 1.004275e+02, Final cost: 9.976248e+01, Termination: CONVERGENCE
2018-10-13 21:47:38,401 DEBUG: Ceres Solver Report: Iterations: 1, Initial cost: 9.988421e+01, Final cost: 9.965775e+01, Termination: CONVERGENCE
2018-10-13 21:47:38,710 DEBUG: Ceres Solver Report: Iterations: 50, Initial cost: 2.006824e+02, Final cost: 1.940284e+02, Termination: NO_CONVERGENCE
2018-10-13 21:47:38,711 INFO: Removed outliers: 0
2018-10-13 21:47:38,715 INFO: -------------------------------------------------------
2018-10-13 21:47:38,741 INFO: 20181013_214537.jpg resection inliers: 439 / 553
2018-10-13 21:47:38,900 DEBUG: Ceres Solver Report: Iterations: 5, Initial cost: 2.169324e+02, Final cost: 1.722736e+02, Termination: CONVERGENCE
2018-10-13 21:47:38,900 INFO: Adding 20181013_214537.jpg to the reconstruction
2018-10-13 21:47:38,948 INFO: Re-triangulating
2018-10-13 21:47:39,418 DEBUG: Ceres Solver Report: Iterations: 49, Initial cost: 3.881916e+02, Final cost: 3.463424e+02, Termination: CONVERGENCE
2018-10-13 21:47:39,619 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 3.473913e+02, Final cost: 3.463425e+02, Termination: CONVERGENCE
2018-10-13 21:47:39,620 INFO: Removed outliers: 3
/code/SuperBuild/src/opensfm/opensfm/align.py:87: RuntimeWarning: invalid value encountered in divide
A /= s
/usr/local/lib/python2.7/dist-packages/numpy/linalg/linalg.py:2022: RuntimeWarning: invalid value encountered in det
r = _umath_linalg.det(a, signature=signature)
File “/code/SuperBuild/src/opensfm/bin/opensfm”, line 34, in
command.run(args)
File “/code/SuperBuild/src/opensfm/opensfm/commands/reconstruct.py”, line 21, in run
report = reconstruction.incremental_reconstruction(data)
File “/code/SuperBuild/src/opensfm/opensfm/reconstruction.py”, line 1177, in incremental_reconstruction
data, graph, reconstruction, remaining_images, gcp)
File “/code/SuperBuild/src/opensfm/opensfm/reconstruction.py”, line 1113, in grow_reconstruction
align_reconstruction(reconstruction, gcp, config)
File “/code/SuperBuild/src/opensfm/opensfm/align.py”, line 20, in align_reconstruction
apply_similarity(reconstruction, s, A, b)
File “/code/SuperBuild/src/opensfm/opensfm/align.py”, line 42, in apply_similarity
shot.pose.set_rotation_matrix(Rp)
File “/code/SuperBuild/src/opensfm/opensfm/types.py”, line 85, in set_rotation_matrix
raise ValueError(“Determinant not 1”)
ValueError: Determinant not 1
plasm.execute(niter=1)
File “/code/scripts/run_opensfm.py”, line 133, in process
(context.pyopencv_path, context.opensfm_path, tree.opensfm))
File “/code/opendm/system.py”, line 34, in run
Exception: Child returned 1
re posting. Thank you so much!
Please re-open a new topic, this time following the instructions. Thanks.
Instructions:
STOP! Having issues processing images with WebODM?
1. Search the forum to see if this problem happened to other users.
2. Check https://github.com/OpenDroneMap/WebODM/issues for similar problems.
3. Check https://github.com/OpenDroneMap/OpenDroneMap/issues for similar problems.
Found nothing? Continue below, making sure to:
1. Include a link to your images! You can use https://www.dropbox.com or https://drive.google.com. No images = difficult to help.
2. Copy/paste the entire task output (not just parts of it) for everyone to read.
3. Did you fine tune any parameters? Which ones?
4. What browser are you using? What operating system? How did you install WebODM? Be precise.
5. DO NOT address your message to the moderator, a core developer, or any other specific user. The forum is a place where everyone can help answer questions, not just one particular user! Be inclusive of everyone.
6. DO NOT reply to a topic that is several months old (unless you are posting the answer to a solution). Open a new topic instead.
7. DO be kind and polite to others.
Remove this notice before posting. Thank you so much!
