ClusterODM Windows Native - Blank UI Page
Hello All,
We just got an instance of ClusterODM working, on a Windows 10 Enterprise machine.
When we launch the Web UI, all it shows is a page without any configuration options.
Is this normal?
Screenshot 2021-06-19 18.51.58_cr
Have you launched any processing nodes to interact with ClusterODM?
Hello Saijin!
We have two processing nodes that are functioning.
Node 1 resides on the main host.
Node 2 resides on the second host.
Hello Saijin!
We have launched ClusterODM on the main host.
WebODM Windows Native is running on both hosts.
There is currently a project that is running. There are two tasks in the project that are running.
Task 1 is using the node on Host 1
Task 2 is using the node on Host 2
There have been some recent improvements to the ClusterODM web interface, but most of the configuration (including adding modes) probably still needs done via telnet. Check GitHub - OpenDroneMap/ClusterODM: A NodeODM API compatible autoscalable load balancer and task tracker for easy horizontal scaling ♆ and check out the readme for more on adding nodes to the cluster.
We will try that, next.
