ClusterODM output ignores skip_report False
I’m running my jobs through WebODM with ClusterODM as the target, all on Windows 10.
When the jobs complete, no report is generated. The skip_report parameter is not turned on in WebODM. The odm_report folder only contains a shots.geojson. The final log file doesn’t mention anything about skipping reports, but I seem to recall seeing a “No report generated” or similar message as split_merge jobs return to the main node.
Has anyone encountered this, or what am I doing wrong?
Reports aren’t yet supported for split merge, I think.
Thank you!
