As smathermather-cm wrote elsewhere that it’s important to set the --max-images
flag arbitrarily high on the primary machine.
Primary machine NodeODM setup like
docker run -p 3001:3000 opendronemap/nodeodm -q 2 --max-images 1000000
Rest of cluster NodeODM setup like
docker run -p 3000:3000 opendronemap/nodeodm -q 2 --max-images 200
However, my secondary machines are getting job sizes of >400 images. Also the “main” named Task of 1123 images usually shows up on the localhost:3000
page of a secondary machine.
I understand that --max-images
is an average, but I’m mostly concerned about the main task showing up on less powerful machines. Cluster keeps failing due to running out of RAM, so trying to nail down the issue.
This smells like user error, but I’ve reset each machine with the parameters listed above.
Lowest RAM on a secondary machine is 64gb. Thank you!
