Hello all.
I’m running a ClusterODM with multiple nodes and processing tasks through the WebODM GUI.
I’ve got the cluster IP address set as the Processing Node in the WebODM GUI, and I also set the --sm-cluster
value to the IP:port for the cluster. This setup has worked well and most jobs run to completion.
If a task fails, WebODM will fail to restart if the --sm-cluster
parameter is formatted like 192.168.1.1:3000
. You have to go back into the settings and reformat like http://192.168.1.1:3000
. WebODM error message provides the format.
Has anyone else experienced this? I realize this is nitpicky, but it seems like if the input parameter succeeds in one case, it should also succeed when re-running.
Edit: I did fresh docker pull
s for my cluster yesterday - so everything should be most recent.
