ClusterODM can't create machine -- why?
So I thought I’d try out ClusterODM to build ultra-quality products from my datasets.
On my local machine, I updated my checkout, built a DigitalOcean JSON file in ./asr.json, modified the docker-compose.yml to properly access the file, and started it up.
I remembered to install and start docker-machine, and to lock the nodeodm-1 that is spun up so things would run in the cloud. Here is the output for the opendronemap/clusterodm container:
info: ClusterODM 1.5.3 started with PID 1
info: Starting admin CLI on 8080
warn: No admin CLI password specified, make sure port 8080 is secured
info: Starting admin web interface on 10000
warn: No admin password specified, make sure port 10000 is secured
info: Cloud: LocalCloudProvider
info: ASR: DigitalOceanAsrProvider
info: Can write to S3
info: Found docker-machine executable
info: Loaded 1 nodes
info: Loaded 0 routes
info: Starting http proxy on 3000
info: Trying to create machine... (1)
warn: Cannot create machine: Error: docker-machine exited with code 1
info: Trying to create machine... (2)
info: Trying to create machine... (3)
info: Trying to create machine... (4)
info: Trying to create machine... (5)
info: Trying to create machine... (6)
info: Trying to create machine... (7)
info: Trying to create machine... (8)
info: Trying to create machine... (9)
info: Trying to create machine... (10)
What am I doing wrong?
