ClusterODM cannot upload task data to s3
Good morning,
Trying to debug a Clusterodm pipeline.
ClusterODM test.txt file is uploading fine when initiated.
My Bucket is configured for Public access.
When a split task fail,all nodes are unable to upload the error files to the s3 bucket with error:
[WARNING] LRE: submodel_0001 failed with: (32a1fdd5-fdb2-495e-b6c6-98cc0873de57) failed with task output: [INFO] ODM app finished - Sun Mar 26 08:40:38 2023
Compressing all.zip
Uploading 1 files to S3…
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 0
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 1
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 2
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 3
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 4
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 5
Cannot upload file to S3: The bucket does not allow ACLs (AccessControlListNotSupported), retrying… 6
Full log saved at /var/www/data/b7b19ba9-3b75-40f2-9d0d-aa3390536e74/submodels/submodel_0001/error.log
The docker run command for nodeodm has all flags correct when created by the docker machine.
Maybe some part in the code in ODM missing the acl-public read command aws requires?
Any help will be great.
Found the problem.Aparently now you need to Enable ACL at amazon S3 and grand public access from within ACL management tab.
