Cluster ODM Autoscale - Help
“message”: “LRE: Downloading assets for submodel_0001”,
“type”: “info”
“message”: “LRE: submodel_0001 failed with: Unexpected status code: 301”,
“type”: “warning”
“message”: “LRE: Cleaning up remote task (820def24-dbcd-4744-8415-3f47866d6ee4)… OK”,
“type”: “info”
“message”: “LRE: Re-queueing submodel_0001 (retries: 1)”,
“type”: “info”
I am trying to setup autoscale to process the images but getting stuck here. After the remote processing is done the downloading assests is causing an issue. But the results are getting uploaded in the s3 bucket
@pierotofy Can u help me understand why this is happening
I tried setting it up without the autoscale config file and it worked fine and it was downloading but once the config file is added the processing is working fine but to align the submodels it downloads the results into the processing machine. The downloading is not working and the above error is happening
