I search for a way to keep the added nodes persistent in the config.js but i have not found a way for this. Does Someone has an idea how to archiv this?
Are you using docker? If so, mount a volume (via -v
) for the /var/www/data
directory.
docker run --rm -ti -p 3000:3000 -p 8080:8080 -v $(pwd)/clusterodm-data:/var/www/data opendronemap/clusterodm
Yes I use docker. I will try this. Thanks for your help, I thought there may be a config file for this.
There is (kind of), it gets created in that folder when you run the application and add a new node (look for a file called nodes.json
Okay that’s great. I will try this and will keep this thread updated on the usage for this. Thanks pierotofy.
/ClusterODM/docker/data#
as I can see, I can set even the “missed” token parameter to secure the nodes and cluster. But at the moment it does not use the node.json file. The clusterodm is blank when asked with the browser.
