Checking if a task has hung
How do i check if a task has failed / hung without an exit 1 or error given. I started a 177 image task at 1pm 18th and at 9am 19th it is still running with the last few lines here :
Clamping qualities to 8.47137 within normalization.Clamping qualities to 8.47137 within normalization.Clamping qualities to 8.47137 within normalization.
Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…Writing data cost file…
done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.done.
htop doesnt show much movement in resources as well.
Options are: Options: dsm: true, mesh-octree-depth: 12, dem-resolution: 0.04, orthophoto-resolution: 40
