Changing the directory location of the ODM generated Outputs
I was working on ODM for few weeks in ubuntu 20.04, I am new to this. I wanted to ask if their is any way to change the location of outputs of the the overall ODM workflow like dem, point clouds and all to a different location? As in default it store all the data in the same dataset/code/ folder as /odm_dem, odm_filterpoints etc.
You could try passing the --copy-to parameter to copy the results to another location you desire:
https://docs.opendronemap.org/arguments/copy-to/
Thank you for such a quick a response. It works for me… Cheers!
