Changing default options for a node?
I’m new to WebODM, so forgive me if this is a stupid question. I’d like to change the default options for a node, but for the life of me I can’t find out where to? Can anyone point me in the right direction.
What I mean by that is that everytime I upload images for a new task I have to run through the list setting the options I like. Is there a way to make the ones I like default?
You could create a preset.
Thanks that works for me! I’ll set that up and train the users.
To expand this question a little, where is the configuration for the node applied? As in, the processing node’s config. For example, I’ve been looking for where to change the number of tasks that can run concurrently from 2 (either up or down, depending on how much RAM I have in the system I’m using at the time). I’ve been using the API a lot but I can only find where to read the current values in there, not set any values (either permanently or when executing a job).
For instance, it would be useful to force an important job to run immediately regardless of queue size or queue length.
