Change the WebODM installation destination
I bought the installer version.
The C drive of my PC has a small capacity, so I want to install it on the D drive with a large capacity.
And , I also want to set the working directory to the D drive.
I’m sorry, because English is not my native language.
Hello Sakuya_izayoi,
To help you with this, more information would be needed. As you do not only install and run one XXXX.exe, it is just not done with changing one path. E.g if you run everything on Windows 10, there would be a VM running linux which runs docker containers. So the point here is the location of the memory of your VM. And to help you to configure that it would be necessary to know what VM you are using: is it e.g. Microsoft Hyper-V with Windows 10 pro or Oracle VM with Windows 10 home or are you already working with Linux?
Kind regards
Yven
iwaend Thank you for your reply.
I have two PC.So I have “Microsoft Hyper-V with Windows 10 pro” and “Oracle VM with Windows 10 home”.
Please give me guidance.
