Change location for the VM/disk.vmdk
Hello, I hope I post this on the correct forum.
I am new to opendronemap/webodm and have som questions.
I have done some tests with example datasets from this site. The problem is that my c: [this seems to be the default location] is running out of space.
I would like to change the location [to a larger HD] on my VM for the processed task I am running on the WEBODM, but I am failing to do so.
I am on windows 10, virtualbox 5.2, docker toolbox.
Can anybody help me with this.
Regards Mattias
Is this not possible?
Posted in the wrong forum?
//M
Hey @mattias, it’s possible, this link should help: https://dirkstrauss.com/moving-virtualbox-vm/
Thank you!
//M
@pierotofy - It seems that the change of location for the VM worked, but it has caused a problem I have not previously noted.
When WEBODM process a data set, it will as usual come to this point:
Post Processing: Done (• ᴗ •) و!
Compressing all.zip
Unfortunately, application seems to continue running and does not end, no map is presented. What could be the problem?
Having the same issue but mine does it when I use GCP points.
Any luck finding the issue or a work around
