Anton
Hello everyone,
I´m using WebODM now and generating good images.
Now I try to insert the GCP´s in my file.
I understand the process and how to do it.
But how to convert my GPS measured points to usable points in WebODM?
Measured in M28 coordinate system - AUSTRIA
I tried a few different EPSG´s but none of them worked.
Example file:
EPSG:31254
EPDR1 -36425.184 252137.249 660.498
EPDR2 -36447.363 252146.300 664.982
EPDR3 -36442.487 252157.973 666.889
EPDR4 -36418.469 252151.086 661.132
Thanks a lot !
Welcome, Anton!
Sorry for the trouble.
Our current CRS database is limited to PROJ4-compatible CRSs, and might be missing some EPSG definitions.
The best way to check is to use something like https://epsg.io to see if your CRS has a PROJ4 definition, and to use that.
So, for your case of EPSG:31254:
The PROJ4 string is:
+proj=tmerc +lat_0=0 +lon_0=10.33333333333333 +k=1 +x_0=0 +y_0=-5000000 +ellps=bessel +towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232 +units=m +no_defs
Available here:
http://epsg.io/31254.proj4
system
Closed
#4
