Hello or good evening to all depending on where in the world we are …
I came across a software which is a little known, well not for me since yesterday!
it’s the one we use a lot to do missions with our drones. you see in the photos
In short, it piqued my curiosity and I did 2 tests that I had through webodm.
error code 1, on the first one (450 photos)
for info I’m currently trying to redo the 450 photos
I repeat it is a test, it’s the same
thank you for your opinion
Good evening
Laurent
i will try to put on google drive a link !!!
for info, I have a mac 3GHZ 6 Hearts I allocated
CPU '3)
64 GB in all and 25 GB on docker
1.5 GB swap
disk image 80 GB
I’m sure it’s not the “right dose”
Allocate more RAM!
Can you give it maybe 56GB or so?
as much ! ?
ok, i will try
I was wondering, in fact, if someone has already done a test with this software, while waiting for me to give you the photos?
Thank you all
the rendering on 300 textured 3D photos is a bit rubbish!
here it is the place of the capitol of Toulouse in France
Uploading: place du capitole Toulouse 301 photos.jpeg…
we see that there is a problem here …
for 301 photos, webodm “took” 27mn and 18 seconds and for the other project, it’s buggy, 15mn 32 and see the running bar, it works but it lags!
webodm.jpeg|690x94
I spent the ram at 40 GB and I still have the message process exited with code 1, I’m trying to send you the link of the 450 photos today
Thank you
Laurent
system
Closed
4 January 2021 21:05
#9
