I desperatly try to get ODM running on my new Linux machine. Unfortunatly I am not 100% familiar with this environment, but I am getting there slowly
I think I managed to install everything as explained in the documentation (Installation and Getting Started — OpenDroneMap 3.0.5 documentation), but when I enter ./webodm.sh start I get the following and localhost:8000 doesn’t respond:
hecking for docker… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm=1
/usr/lib/python3/dist-packages/paramiko/transport.py:236: CryptographyDeprecationWarning: Blowfish has been deprecated
“class”: algorithms.Blowfish,
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.10/http/client.py”, line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.10/http/client.py”, line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.10/http/client.py”, line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.10/http/client.py”, line 1037, in _send_output
self.send(msg)
File “/usr/lib/python3.10/http/client.py”, line 975, in send
self.connect()
File “/usr/local/lib/python3.10/dist-packages/docker/transport/unixconn.py”, line 30, in connect
sock.connect(self.unix_socket)
PermissionError: [Errno 13] Permission denied
File “/usr/local/lib/python3.10/dist-packages/requests/adapters.py”, line 489, in send
resp = conn.urlopen(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 755, in urlopen
retries = retries.increment(
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3/dist-packages/six.py”, line 718, in reraise
raise value.with_traceback(tb)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
File “/usr/local/lib/python3.10/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.10/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.10/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/local/lib/python3.10/dist-packages/requests/sessions.py”, line 600, in get
return self.request(“GET”, url, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/requests/sessions.py”, line 587, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.10/dist-packages/requests/sessions.py”, line 701, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/requests/adapters.py”, line 547, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
File “/usr/local/bin/docker-compose”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.10/dist-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/local/lib/python3.10/dist-packages/compose/cli/main.py”, line 200, in perform_command
project = project_from_options(‘.’, options)
File “/usr/local/lib/python3.10/dist-packages/compose/cli/command.py”, line 60, in project_from_options
return get_project(
File “/usr/local/lib/python3.10/dist-packages/compose/cli/command.py”, line 152, in get_project
client = get_client(
File “/usr/local/lib/python3.10/dist-packages/compose/cli/docker_client.py”, line 41, in get_client
client = docker_client(
File “/usr/local/lib/python3.10/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/docker/api/client.py”, line 197, in init
self._version = self._retrieve_server_version()
File “/usr/local/lib/python3.10/dist-packages/docker/api/client.py”, line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
Did I miss anything?
Thanks in advance for your help.
