I need a Guru!
I installed the latest and greatest version of opendronemap last night on to an AWS vm. After competion (about 1 hour, 15 min) I saw the “happy” message:
Congratulations! └@(・◡・)@┐
If there are no errors, WebODM should be up and running!
Open a web browser and navigate to http://3.81.229.187
Clearly something went south on the install with that address.
I ran netstat -anc to see what port may have actually been used in the process.
I found NodeODM on port 3000 – this is running without issue.
The only other ports that are open/listening, 6006 , which is tensorboard–and working
8500 and 8501.
On 8500 I get the message:
This page isn’t working
compute-1.amazonaws.com** sent an invalid response.
ERR_INVALID_HTTP_RESPONSE
… and on 8501, I get the message:
Not Found
… I am so green to AWS installs, I can’t find the logs–does anyone know where I should look? Any ideas on what the story might be?
BTW, I also did a restart on all the services:
sudo service nodeodm restart
sudo service webodm-nginx restart
sudo service webodm-gunicorn restart
sudo service webodm-celery restart
sudo service webodm-celerybeat restart
… no errors… no messages.
