Hello guys,
Extremely new member here.
Tried to install WebODM using Git and Docker, gave it a try, and got some good results on small projects. Now I’m trying something a bit larger and it is not able to process because it lacks memory.
First I tried Ultra Quality, then High Resolution, now Default, and nothing works. Thought it could be that this computer couldn’t handle it at first but I’m starting to doubt it!
I’m currently processing it again and I saw this in the log:
09:25:08 [App] RAM: 15.46GB Physical Memory 4.00 GB Virtual Memory
This laptop has 32GB RAM and 16GB VRAM, I’m clearly doing something wrong.
Can anyone guide me here?
While I was writting this, it failed again, processing node out of memory:
Geometric-consistent estimated depth-maps 623 (97.50%, 9m54s, ETA 15s)…
Geometric-consistent estimated depth-maps 624 (97.65%, 9m54s, ETA 14s)…
Geometric-consistent estimated depth-maps 625 (97.81%, 9m55s, ETA 13s)…
Geometric-consistent estimated depth-maps 626 (97.97%, 9m56s, ETA 12s)…
Geometric-consistent estimated depth-maps 627 (98.12%, 9m57s, ETA 11s)…
Geometric-consistent estimated depth-maps 628 (98.28%, 9m58s, ETA 10s)…
Geometric-consistent estimated depth-maps 629 (98.44%, 9m59s, ETA 9s)…
Geometric-consistent estimated depth-maps 630 (98.59%, 10m, ETA 8s)…
Geometric-consistent estimated depth-maps 631 (98.75%, 10m1s, ETA 7s)…
Geometric-consistent estimated depth-maps 632 (98.90%, 10m2s, ETA 6s)…
Geometric-consistent estimated depth-maps 633 (99.06%, 10m3s, ETA 5s)…
Geometric-consistent estimated depth-maps 634 (99.22%, 10m4s, ETA 4s)…
Geometric-consistent estimated depth-maps 635 (99.37%, 10m5s, ETA 3s)…
Geometric-consistent estimated depth-maps 636 (99.53%, 10m6s, ETA 2s)…
Geometric-consistent estimated depth-maps 637 (99.69%, 10m7s, ETA 1s)…
Geometric-consistent estimated depth-maps 638 (99.84%, 10m7s, ETA 952ms)…
Geometric-consistent estimated depth-maps 639 (100.00%, 10m8s, ETA 0ms)…
Geometric-consistent estimated depth-maps 639 (100%, 10m8s761ms)
Filtered depth-maps 1 (0.16%, 18s, ETA 0ms)…
Filtered depth-maps 26 (4.07%, 18s, ETA 7m)…
Filtered depth-maps 48 (7.51%, 18s, ETA 3m)…
Filtered depth-maps 71 (11.11%, 18s, ETA 2m)…
Filtered depth-maps 96 (15.02%, 18s, ETA 1m)…
Filtered depth-maps 114 (17.84%, 18s, ETA 1m)…
Filtered depth-maps 130 (20.34%, 18s, ETA 1m)…
Filtered depth-maps 139 (21.75%, 18s, ETA 1m)…
Filtered depth-maps 156 (24.41%, 18s, ETA 58s)…
Filtered depth-maps 165 (25.82%, 19s, ETA 54s)…
Filtered depth-maps 174 (27.23%, 19s, ETA 51s)…
Filtered depth-maps 190 (29.73%, 19s, ETA 45s)…
Filtered depth-maps 202 (31.61%, 19s, ETA 42s)…
Filtered depth-maps 216 (33.80%, 19s, ETA 38s)…
Filtered depth-maps 224 (35.05%, 19s, ETA 36s)…
Filtered depth-maps 235 (36.78%, 19s, ETA 34s)…
Filtered depth-maps 252 (39.44%, 19s, ETA 30s)…
Filtered depth-maps 258 (40.38%, 20s, ETA 29s)…
Filtered depth-maps 274 (42.88%, 20s, ETA 26s)…
Filtered depth-maps 284 (44.44%, 20s, ETA 25s)…
Filtered depth-maps 292 (45.70%, 20s, ETA 24s)…
Filtered depth-maps 303 (47.42%, 20s, ETA 22s)…
Filtered depth-maps 313 (48.98%, 20s, ETA 21s)…
Filtered depth-maps 328 (51.33%, 20s, ETA 19s)…
Filtered depth-maps 337 (52.74%, 20s, ETA 18s)…
Filtered depth-maps 356 (55.71%, 20s, ETA 16s)…
Filtered depth-maps 363 (56.81%, 21s, ETA 16s)…
Filtered depth-maps 370 (57.90%, 21s, ETA 15s)…
Filtered depth-maps 378 (59.15%, 21s, ETA 14s)…
Filtered depth-maps 386 (60.41%, 21s, ETA 14s)…
Filtered depth-maps 395 (61.82%, 21s, ETA 13s)…
Filtered depth-maps 403 (63.07%, 21s, ETA 12s)…
Filtered depth-maps 405 (63.38%, 21s, ETA 12s)…
Filtered depth-maps 412 (64.48%, 21s, ETA 12s)…
Filtered depth-maps 429 (67.14%, 21s, ETA 10s)…
Filtered depth-maps 443 (69.33%, 22s, ETA 9s)…
Filtered depth-maps 456 (71.36%, 22s, ETA 8s)…
Filtered depth-maps 469 (73.40%, 22s, ETA 8s)…
Filtered depth-maps 474 (74.18%, 22s, ETA 7s)…
Filtered depth-maps 488 (76.37%, 22s, ETA 6s)…
Filtered depth-maps 503 (78.72%, 22s, ETA 6s)…
Filtered depth-maps 512 (80.13%, 22s, ETA 5s)…
Filtered depth-maps 526 (82.32%, 22s, ETA 4s)…
Filtered depth-maps 538 (84.19%, 22s, ETA 4s)…
Filtered depth-maps 542 (84.82%, 23s, ETA 4s)…
Filtered depth-maps 556 (87.01%, 23s, ETA 3s)…
Filtered depth-maps 569 (89.05%, 23s, ETA 2s)…
Filtered depth-maps 576 (90.14%, 23s, ETA 2s)…
Filtered depth-maps 590 (92.33%, 23s, ETA 1s)…
Filtered depth-maps 605 (94.68%, 23s, ETA 1s)…
Filtered depth-maps 622 (97.34%, 23s, ETA 653ms)…
Filtered depth-maps 633 (99.06%, 24s, ETA 228ms)…
Filtered depth-maps 639 (100%, 24s137ms)
Fused depth-maps 0 (0.00%, 573ms, ETA 0ms)…
Fused depth-maps 1 (0.16%, 1s, ETA 0ms)…
Fused depth-maps 2 (0.31%, 1s, ETA 0ms)…
Fused depth-maps 3 (0.47%, 1s, ETA 0ms)…
Fused depth-maps 4 (0.63%, 1s, ETA 0ms)…
Fused depth-maps 5 (0.78%, 2s, ETA 0ms)…
Fused depth-maps 7 (1.10%, 2s, ETA 3m)…
Fused depth-maps 8 (1.25%, 2s, ETA 3m)…
Fused depth-maps 9 (1.41%, 3s, ETA 4m)…
Fused depth-maps 10 (1.56%, 3s, ETA 3m)…
Fused depth-maps 12 (1.88%, 4s, ETA 3m)…
Fused depth-maps 14 (2.19%, 4s, ETA 3m)…
Fused depth-maps 16 (2.50%, 4s, ETA 2m)…
Fused depth-maps 18 (2.82%, 5s, ETA 2m)…
Fused depth-maps 20 (3.13%, 5s, ETA 2m)…
Fused depth-maps 21 (3.29%, 5s, ETA 2m)…
Fused depth-maps 22 (3.44%, 5s, ETA 2m)…
Fused depth-maps 24 (3.76%, 6s, ETA 2m)…
Fused depth-maps 25 (3.91%, 6s, ETA 2m)…
Fused depth-maps 27 (4.23%, 6s, ETA 2m)…
Fused depth-maps 30 (4.69%, 6s, ETA 2m)…
Fused depth-maps 32 (5.01%, 7s, ETA 2m)…
Fused depth-maps 33 (5.16%, 7s, ETA 2m)…
Fused depth-maps 34 (5.32%, 7s, ETA 2m)…
Fused depth-maps 35 (5.48%, 7s, ETA 2m)…
Fused depth-maps 37 (5.79%, 7s, ETA 2m)…
Fused depth-maps 39 (6.10%, 7s, ETA 2m)…
Fused depth-maps 41 (6.42%, 8s, ETA 2m)…
Fused depth-maps 42 (6.57%, 8s, ETA 2m)…
Fused depth-maps 45 (7.04%, 9s, ETA 2m)…
Fused depth-maps 46 (7.20%, 9s, ETA 2m)…
Fused depth-maps 47 (7.36%, 10s, ETA 2m)…
Fused depth-maps 48 (7.51%, 10s, ETA 2m)…
Fused depth-maps 51 (7.98%, 10s, ETA 2m)…
Fused depth-maps 52 (8.14%, 10s, ETA 2m)…
Fused depth-maps 55 (8.61%, 11s, ETA 1m)…
Fused depth-maps 58 (9.08%, 12s, ETA 2m)…
Fused depth-maps 61 (9.55%, 12s, ETA 2m)…
Fused depth-maps 65 (10.17%, 12s, ETA 1m)…
Fused depth-maps 66 (10.33%, 13s, ETA 1m)…
Fused depth-maps 69 (10.80%, 13s, ETA 1m)…
Fused depth-maps 72 (11.27%, 13s, ETA 1m)…
Fused depth-maps 73 (11.42%, 13s, ETA 1m)…
Fused depth-maps 75 (11.74%, 13s, ETA 1m)…
Fused depth-maps 78 (12.21%, 14s, ETA 1m)…
Fused depth-maps 79 (12.36%, 14s, ETA 1m)…
Fused depth-maps 82 (12.83%, 15s, ETA 1m)…
Fused depth-maps 83 (12.99%, 15s, ETA 1m)…
Fused depth-maps 84 (13.15%, 16s, ETA 1m)…
Fused depth-maps 85 (13.30%, 16s, ETA 1m)…
Fused depth-maps 86 (13.46%, 16s, ETA 1m)…
Fused depth-maps 88 (13.77%, 16s, ETA 1m)…
Fused depth-maps 89 (13.93%, 17s, ETA 1m)…
Fused depth-maps 91 (14.24%, 17s, ETA 1m)…
Fused depth-maps 92 (14.40%, 18s, ETA 1m)…Killed
[WARNING] Sub-scene /var/www/data/8d5c6ac6-2aec-42dd-a9e5-b85130dbc6e2/opensfm/undistorted/openmvs/scene_0000.mvs could not be reconstructed, skipping…
[WARNING] Could not compute PLY for subscene /var/www/data/8d5c6ac6-2aec-42dd-a9e5-b85130dbc6e2/opensfm/undistorted/openmvs/scene_0000.mvs
[INFO] Merging 0 scene files
[ERROR] Could not compute dense point cloud (no PLY files available).
