Can't complete large jobs
I’m a new user to WebODM and have been trying some sample data sets. I’ve been unable to complete large jobs. I’ve tried this batch of images several times with different settings based on what I’ve seen on the forum without any success.
Link to images: https://drive.google.com/open?id=1aSca-Xxj_H83C9BsMuyuT7oD7JV6Go66
Link to task output: https://drive.google.com/open?id=1K7K3pvqEtSiLnRw17iASsYxtxmZ8BSzV
My docker setup:
CPU: 3
Memory: 27392
Swap: 1024
Disk image max size: 64.42GB
My last attempt
Created on: 8/7/2018, 9:44:41 AM
Status: Failed
Options: mesh-octree-depth: 10, min-num-features: 14000, orthophoto-resolution: 40, dsm: true, use-pmvs: true
Number of images: 1385
Processing time: 16:16:03
Error Code: Process exited with code 1
I’ve also tried increasing the mesh-octree-depth.
mesh-octree-depth: 12, min-num-features: 16000, orthophoto-resolution: 40, dsm: true, use-pmvs: true
mesh-octree-depth: 14, min-num-features: 16000, orthophoto-resolution: 40, dsm: true, use-pmvs: true
Any suggestions would be appreciated.
Have you tried the split-merge approach documented here?: http://docs.opendronemap.org/large.html
It still needs some work, but may help in accomplishing what you need.
As it has been suggested, either look at the split-merge feature or resize your images to a much smaller resolution. Unfortunately 32GB of RAM are not a whole lot for processing 1300+ images.
