Can't complete large job on a huge memory machine
IMPORTANT! Having issues processing images?
  1. Search the forum to see if this problem happened to other users.
  2. Check https://github.com/OpenDroneMap/ODM/issues and https://github.com/OpenDroneMap/WebODM/issues for similar problems.
Found nothing? Great, explain in detail the problem, making sure to:
  1. Include a link to your images! You can use https://www.dropbox.com or https://drive.google.com. No images = difficult to help.
  2. Copy/paste the entire task output (not just parts of it) for everyone to read.
  3. Did you fine tune any parameters? Which ones?
  4. If applicable, what browser are you using? What operating system? How did you install the software? Be precise.
  5. DO NOT address your message to the moderator, a core developer, or any other specific user. The forum is a place where everyone can help answer questions, not just one particular user! Be inclusive of everyone.
  6. DO NOT reply to a topic that is several months old (unless you are posting the answer to a solution). Open a new topic instead.
  7. DO be kind and polite to others.
Remove this notice before posting. Thank you so much!
I have tried this very large data set of 1,788 images
Link to images: https://drive.google.com/file/d/1zetoubpP43ZK-cQp1F2_1z1sLn82YDtv/view?usp=sharing
Link to task output: https://drive.google.com/file/d/14o79Qd19t6Ed2tH8UO6AXib8qBFrO8ey/view?usp=sharing
My docker setup:
CPU: 15
Memory: 200 GB
Swap: 3584
Disk image max size: 160GB
My machine is HP DL380G7 with dual Xeon 5630 with 256GB of Ram with 160 GB left in Harddisk Space
My last attempt
[INFO] Running dense reconstruction. This might take a while. Please be patient, the process is not dead or hung.
[INFO] Process is running
[INFO] running /code/SuperBuild/src/elibs/mve/apps/dmrecon/dmrecon -s3 --progress=silent --local-neighbors=2 “/var/www/data/f08279fc-f974-4e72-b17e-5b58e091bad3/mve”
MVE Depth Map Reconstruction (built on Jul 31 2019, 14:30:46)
Initializing scene with 1454 views…
Initialized 1454 views (max ID is 1787), took 159ms.
Reading Photosynther file (1788 cameras, 672415 features)…
Reconstructing all views…
My only setting was only Options: dsm: true
picture are not compress nor their is no use of fast orthro
And I have seen no change in the console windows for at least 5 hours, is their any wrong ot it is a normal process?
Thank you.
<-- this
YES. Succeeded It took very long time indeed. Thanks piero.
