I have WebODM running on an Ubuntu machine and recently updated it with the WebODM Server Installer (rev 04/08/19). I don’t remember the rev prior to that but since I updated the server, I can’t cancel jobs. When I click on the cancel button, it never actually disappears. It shows “cancelling…” with the hourglass next to it.
Here’s a screenshot:
I’ve found that I can delete the entire project from the web interface, just not specific tasks. Has anyone else run into this and is there a way around that? I’ve gone into the folders to see if I can simply remove the specific folders but it’s difficult to determine which folders belong to specific projects/tasks.
Yes I have this problem regularly when cancelling or deleting tasks mid-upload or mid-process. I raised a bug report here that you may wish to contribute to:
I found after I updated to 1.0.2 i could restart the task. the task showed “Cannot cancel a task that has no processing node or UUID” but I could edit and restart.
i saw that the fix was rolled into the master a little while ago. i ran the installer on the WebODM server but the tasks are still showing canceling… is there i need to run to clear that message state so i can restart them? or do they have to be deleted and added back?
