with latest docker image 88860a6a7c09 ODM stop with the following error
‘’‘[Cannot write log.json: [Errno 28] No space left on device’‘’
I am running ODM with Singularity on a grid computer. With more or less the same data, I have this error for maybe 30% of the different runs. Maybe the docker/singularity image needs some space to run somewhere… 70% of other runs do not failed with exactly the same parameters and same number of pictures. I am not running of space on my disk
023-03-27 16:14:15,771 DEBUG: Found 145488 points in 16.967890977859497s
2023-03-27 16:14:29,972 DEBUG: Found 135873 points in 16.014127731323242s
2023-03-27 16:14:30,022 DEBUG: Found 133640 points in 16.09254240989685s
2023-03-27 16:14:30,146 DEBUG: Found 136841 points in 16.33139395713806s
2023-03-27 16:14:30,607 DEBUG: Found 140882 points in 16.61655282974243s
Exception ignored in: <function ZipFile.__del__ at 0x14e7a915d1f0>
File "/usr/lib/python3.9/zipfile.py", line 1807, in __del__
self.close()
File "/usr/lib/python3.9/zipfile.py", line 1824, in close
self.fp.seek(self.start_dir)
ValueError: seek of closed file
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
self.close()
File "/code/SuperBuild/install/bin/opensfm/bin/opensfm_main.py", line 25, in <module>
commands.command_runner(
File "/code/SuperBuild/install/bin/opensfm/opensfm/commands/command_runner.py", line 38, in command_runner
command.run(data, args)
File "/code/SuperBuild/install/bin/opensfm/opensfm/commands/command.py", line 13, in run
self.run_impl(data, args)
File "/code/SuperBuild/install/bin/opensfm/opensfm/commands/detect_features.py", line 13, in run_impl
detect_features.run_dataset(dataset)
File "/code/SuperBuild/install/bin/opensfm/opensfm/actions/detect_features.py", line 15, in run_dataset
features_processing.run_features_processing(data, data.images(), False)
File "/code/SuperBuild/install/bin/opensfm/opensfm/features_processing.py", line 79, in run_features_processing
parallel_map(process, arguments, processes, 1)
File "/code/SuperBuild/install/bin/opensfm/opensfm/context.py", line 59, in parallel_map
res = Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File "/usr/local/lib/python3.9/dist-packages/joblib/parallel.py", line 1056, in __call__
self.retrieve()
File "/usr/local/lib/python3.9/dist-packages/joblib/parallel.py", line 935, in retrieve
File "/usr/lib/python3.9/multiprocessing/pool.py", line 771, in get
raise self._value
File "/usr/lib/python3.9/multiprocessing/pool.py", line 125, in worker
result = (True, func(*args, **kwds))
File "/usr/local/lib/python3.9/dist-packages/joblib/_parallel_backends.py", line 595, in __call__
return self.func(*args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/joblib/parallel.py", line 262, in __call__
return [func(*args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/joblib/parallel.py", line 262, in <listcomp>
File "/code/SuperBuild/install/bin/opensfm/opensfm/features_processing.py", line 146, in process
read_images(queue, data, images, counter, expected, force)
File "/code/SuperBuild/install/bin/opensfm/opensfm/features_processing.py", line 170, in read_images
queue.put(args, block=True, timeout=full_queue_timeout)
File "/usr/lib/python3.9/queue.py", line 148, in put
raise Full
queue.Full
Child returned 1
File "/code/stages/odm_app.py", line 81, in execute
File "/code/opendm/types.py", line 398, in run
File "/code/opendm/types.py", line 377, in run
File "/code/stages/run_opensfm.py", line 35, in process
File "/code/opendm/osfm.py", line 408, in feature_matching
raise e
File "/code/opendm/osfm.py", line 396, in feature_matching
self.run('detect_features')
File "/code/opendm/osfm.py", line 34, in run
system.run('"%s" %s "%s"' %
File "/code/opendm/system.py", line 110, in run
e[91m[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying/e[0m
