I have not been able to process any data since the latest up date (WebODM 1.9.16) with engine 3.0.0 and get the same error message “Cannot process dataset”. I have used 4 different sets of images assuming perhaps some of my images have errors.
I successfully processed a set of images back on November 2, 2022 but when I made a copy and tried to reprocess the same images I got the same error message “Cannot process dataset”. The only commonality between the processing set the succeeded and the set that failed is update build version.
Am I correct in assuming that there is something in the update build version that has caused these errors to happen. Does anyone have any suggestions as to what I should try next?
I’m having a problem progressing pass this same point on every test I’ve tried with the new build. Could someone review the logs and advise please. console_221206.pdf (1.9 MB) console#1.pdf (4.0 MB)
Thanks for that Gordon, the 929 image ortho took just over 10 hours to complete. never had one take that long before. It was interesting to watch the task manager during the process. CPU went to 90%, Memory used 35% and GPU 12%. Would there be any reason to increase the ram at all? I was thinking of putting through some composite images from different flights to make a more detailed map, probably over 2000 images.
Regards
Gagey
