Cannot process dataset - Part ##
Hi
I have uninstalled and reinstalled WebODM. The photo quality is very good.
Suddenly I am getting a “Cannot process dataset” failure.
There is 815 images in total and I have tried smaller subsets with no success either.
There is tons of overlap and I have upped the min num-features to 40000 too with no success.
Please help.
m
[INFO] Fast orthophoto is turned on, automatically setting --skip-3dmodel
[INFO] Initializing ODM 2.8.5 - Wed Jul 13 17:38:30 2022
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] auto_boundary: True
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: True
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 6
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: 3ad66033-7e42-40e0-9859-c1e6f1355e75
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\images
[INFO] Loading 815 images
[INFO] Found 815 usable images
[INFO] Parsing SRS header: WGS84 UTM 11N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 6000px
[INFO] Photo dimensions for feature extraction: 3000px
[INFO] CUDA drivers detected
[WARNING] Cannot use GPU for feature extraction: Cannot initialize CUDA
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 3000’, ‘feature_min_frames: 10000’, ‘processes: 6’, ‘matching_gps_neighbors: 0’, ‘matching_gps_distance: 0’, ‘matching_graph_rounds: 50’, ‘optimize_camera_parameters: yes’, ‘reconstruction_algorithm: incremental’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘bundle_compensate_gps_bias: yes’, ‘matcher_type: FLANN’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” detect_features “C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\opensfm”
2022-07-13 17:38:39,541 INFO: Capping memory usage to ~ 26502.7890625 MB
2022-07-13 17:38:39,541 INFO: Expecting to process 200 images.
2022-07-13 17:38:39,546 INFO: Reading data for image DSC07647.JPG (queue-size=0
2022-07-13 17:38:39,546 INFO: Reading data for image DSC07919.JPG (queue-size=0
2022-07-13 17:38:39,546 INFO: Reading data for image DSC08192.JPG (queue-size=0
2022-07-13 17:38:40,025 INFO: Reading data for image DSC07648.JPG (queue-size=1
2022-07-13 17:38:40,025 INFO: Extracting ROOT_SIFT features for image DSC07647.JPG
2022-07-13 17:38:40,037 INFO: Reading data for image DSC07920.JPG (queue-size=1
2022-07-13 17:38:40,038 INFO: Extracting ROOT_SIFT features for image DSC07919.JPG
2022-07-13 17:38:40,048 INFO: Reading data for image DSC08193.JPG (queue-size=1
2022-07-13 17:38:40,048 INFO: Extracting ROOT_SIFT features for image DSC08192.JPG
2022-07-13 17:38:40,055 DEBUG: Computing sift with threshold 0.066
2022-07-13 17:38:40,073 DEBUG: Computing sift with threshold 0.066
2022-07-13 17:38:40,081 DEBUG: Computing sift with threshold 0.066
2022-07-13 17:38:40,607 INFO: Reading data for image DSC07649.JPG (queue-size=1
2022-07-13 17:38:40,615 INFO: Reading data for image DSC08194.JPG (queue-size=2
2022-07-13 17:38:40,624 INFO: Reading data for image DSC07921.JPG (queue-size=3
2022-07-13 17:38:41,249 INFO: Reading data for image DSC07650.JPG (queue-size=4
2022-07-13 17:38:41,382 INFO: Reading data for image DSC07922.JPG (queue-size=5
2022-07-13 17:38:41,440 INFO: Reading data for image DSC08195.JPG (queue-size=6
2022-07-13 17:38:41,716 DEBUG: Found 10914 points in 1.6350009441375732s
2022-07-13 17:38:41,716 DEBUG: done
2022-07-13 17:38:41,749 DEBUG: Found 7467 points in 1.6760001182556152s
2022-07-13 17:38:41,749 DEBUG: reducing threshold
2022-07-13 17:38:41,749 DEBUG: Computing sift with threshold 0.044000000000000004
2022-07-13 17:38:41,761 INFO: Reading data for image DSC07651.JPG (queue-size=7
2022-07-13 17:38:42,037 INFO: Reading data for image DSC07923.JPG (queue-size=8
2022-07-13 17:38:42,098 INFO: Reading data for image DSC08196.JPG (queue-size=9
2022-07-13 17:38:42,282 INFO: Reading data for image DSC07652.JPG (queue-size=10
2022-07-13 17:38:42,623 DEBUG: Found 88386 points in 2.567997694015503s
2022-07-13 17:38:42,623 DEBUG: done
2022-07-13 17:38:42,701 INFO: Reading data for image DSC07924.JPG (queue-size=11
2022-07-13 17:38:42,746 INFO: Reading data for image DSC08197.JPG (queue-size=12
2022-07-13 17:38:42,858 INFO: Reading data for image DSC07653.JPG (queue-size=13
Corrupt JPEG data: 134 extraneous bytes before marker 0xc4
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm_main.py”, line 25, in
commands.command_runner(
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\command_runner.py”, line 37, in command_runner
2022-07-13 17:38:42,869 INFO: Extracting ROOT_SIFT features for image DSC07648.JPG
command.run(data, args)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\command.py”, line 12, in run
self.run_impl(data, args)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\detect_features.py”, line 11, in run_impl
detect_features.run_dataset(dataset)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\detect_features.py”, line 15, in run_dataset
features_processing.run_features_processing(data, data.images(), False)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features_processing.py”, line 65, in run_features_processing
parallel_map(process, arguments, processes, 1)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\context.py”, line 56, in parallel_map
res = Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\parallel.py”, line 1061, in call
self.retrieve()
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\parallel.py”, line 940, in retrieve
File “multiprocessing\pool.py”, line 768, in get
File “multiprocessing\pool.py”, line 125, in worker
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib_parallel_backends.py”, line 595, in call
return self.func(*args, **kwargs)
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\parallel.py”, line 262, in call
return [func(*args, **kwargs)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features_processing.py”, line 117, in process
read_images(queue, data, images, counter, expected, force)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features_processing.py”, line 134, in read_images
image_array = data.load_image(image)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 104, in load_image
return self.io_handler.imread(
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py”, line 1464, in imread
return imread_from_fileobject(fb, grayscale, unchanged, anydepth)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py”, line 1228, in imread_from_fileobject
raise IOError(“Unable to load image”)
OSError: Unable to load image
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” match_features “C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\opensfm”
2022-07-13 17:38:47,549 INFO: Matching 7719 image pairs
2022-07-13 17:38:47,549 INFO: Computing pair matching with 6 processes
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\match_features.py”, line 11, in run_impl
match_features.run_dataset(dataset)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\match_features.py”, line 14, in run_dataset
pairs_matches, preport = matching.match_images(data, {}, images, images)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py”, line 56, in match_images
match_images_with_pairs(data, config_override, exifs, pairs),
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py”, line 80, in match_images_with_pairs
matches = context.parallel_map(match_unwrap_args, args, processes, jobs_per_process)
self.retrieve()
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py”, line 210, in match_unwrap_args
matches = match(im1, im2, camera1, camera2, data, config_override, pose)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py”, line 579, in match
p1, p2, matches, matcher_type = _match_descriptors_impl(
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py”, line 353, in _match_descriptors_impl
features_data1 = feature_loader.instance.load_all_data(
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py”, line 109, in load_all_data
features_data = self._load_all_data_masked(data, image)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py”, line 160, in _load_all_data_masked
features_data = self._load_all_data_unmasked(data, image)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py”, line 154, in _load_all_data_unmasked
return self._load_features_nocache(data, image)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py”, line 201, in _load_features_nocache
features_data = data.load_features(image)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 313, in load_features
with self.io_handler.open(features_filepath, “rb”) as f:
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py”, line 1439, in open
return open(*args, **kwargs)
FileNotFoundError: [Errno 2] No such file or directory: ‘C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\opensfm\features\DSC08393.JPG.features.npz’
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\opensfm”
2022-07-13 17:38:48,780 INFO: reading features
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\create_tracks.py”, line 11, in run_impl
create_tracks.run_dataset(dataset)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\create_tracks.py”, line 12, in run_dataset
features, colors, segmentations, instances = tracking.load_features(
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\tracking.py”, line 28, in load_features
features_data = dataset.load_features(im)
FileNotFoundError: [Errno 2] No such file or directory: ‘C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\opensfm\features\DSC07647.JPG.features.npz’
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\3ad66033-7e42-40e0-9859-c1e6f1355e75\opensfm”
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\reconstruct.py”, line 11, in run_impl
reconstruct.run_dataset(dataset)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\reconstruct.py”, line 9, in run_dataset
tracks_manager = data.load_tracks_manager()
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 381, in load_tracks_manager
return pymap.TracksManager.instanciate_from_file(self._tracks_manager_file(filename))
RuntimeError: Can’t read tracks manager file
Can you please try on a current release? WebODM for Windows native is at v1.9.15 Build 65, and ODM stand-alone is at v2.8.7
I will try B but I am seeing build 66 on the download. Still good?
Same deal exactly with 1.9.15 Build 66
[INFO] Initializing ODM 2.8.7 - Wed Jul 13 19:59:43 2022
[INFO] boundary: {}
[INFO] cameras: {}
[INFO] cog: True
[INFO] crop: 3
[INFO] debug: False
[INFO] dsm: False
[INFO] dtm: False
[INFO] gcp: None
[INFO] geo: None
[INFO] merge: all
[INFO] name: ce02a11f-08f5-43ef-8abf-ca5757968343
[INFO] pc_ept: True
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] rolling_shutter: False
[INFO] tiles: False
[INFO] time: False
[INFO] Loading dataset from: C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\images
[INFO] Wrote images database: C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\images.json
[INFO] Using GPU for extracting SIFT features
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 3000’, ‘feature_min_frames: 10000’, ‘processes: 6’, ‘matching_gps_neighbors: 0’, ‘matching_gps_distance: 0’, ‘matching_graph_rounds: 50’, ‘optimize_camera_parameters: yes’, ‘reconstruction_algorithm: incremental’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘matcher_type: FLANN’, ‘feature_type: SIFT_GPU’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” detect_features “C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\opensfm”
2022-07-13 20:00:24,937 INFO: Planning to use 48812.60390625 MB of RAM for both processing queue and parallel processing.
2022-07-13 20:00:24,941 INFO: Scale-space expected size of a single image : 205.18898963928223 MB
2022-07-13 20:00:24,941 INFO: Expecting to queue at most 200 images while parallel processing of 6 images.
2022-07-13 20:00:24,947 INFO: Reading data for image DSC07647.JPG (queue-size=0
2022-07-13 20:00:24,947 INFO: Reading data for image DSC07919.JPG (queue-size=0
2022-07-13 20:00:24,947 INFO: Reading data for image DSC08192.JPG (queue-size=0
2022-07-13 20:00:25,394 INFO: Reading data for image DSC07648.JPG (queue-size=1
2022-07-13 20:00:25,394 INFO: Extracting ROOT_SIFT_GPU features for image DSC07647.JPG
2022-07-13 20:00:25,412 INFO: Reading data for image DSC07920.JPG (queue-size=1
2022-07-13 20:00:25,413 INFO: Reading data for image DSC08193.JPG (queue-size=1
2022-07-13 20:00:25,413 INFO: Extracting ROOT_SIFT_GPU features for image DSC07919.JPG
2022-07-13 20:00:25,413 INFO: Extracting ROOT_SIFT_GPU features for image DSC08192.JPG
2022-07-13 20:00:25,839 DEBUG: No segmentation for DSC07647.JPG, no features masked.
2022-07-13 20:00:25,882 INFO: Reading data for image DSC07649.JPG (queue-size=1
2022-07-13 20:00:25,908 INFO: Reading data for image DSC07921.JPG (queue-size=2
2022-07-13 20:00:25,913 INFO: Reading data for image DSC08194.JPG (queue-size=3
2022-07-13 20:00:26,171 DEBUG: No segmentation for DSC08192.JPG, no features masked.
2022-07-13 20:00:26,268 DEBUG: No segmentation for DSC07919.JPG, no features masked.
2022-07-13 20:00:26,405 INFO: Reading data for image DSC07650.JPG (queue-size=4
2022-07-13 20:00:26,409 INFO: Reading data for image DSC08195.JPG (queue-size=5
2022-07-13 20:00:26,424 INFO: Reading data for image DSC07922.JPG (queue-size=6
2022-07-13 20:00:26,872 INFO: Extracting ROOT_SIFT_GPU features for image DSC07648.JPG
2022-07-13 20:00:26,923 INFO: Reading data for image DSC07923.JPG (queue-size=6
2022-07-13 20:00:26,958 INFO: Extracting ROOT_SIFT_GPU features for image DSC07920.JPG
2022-07-13 20:00:26,971 INFO: Reading data for image DSC08196.JPG (queue-size=6
2022-07-13 20:00:26,983 INFO: Reading data for image DSC07651.JPG (queue-size=7
2022-07-13 20:00:27,249 DEBUG: No segmentation for DSC07648.JPG, no features masked.
2022-07-13 20:00:27,322 DEBUG: No segmentation for DSC07920.JPG, no features masked.
2022-07-13 20:00:27,443 INFO: Reading data for image DSC07924.JPG (queue-size=8
2022-07-13 20:00:27,484 INFO: Reading data for image DSC08197.JPG (queue-size=9
2022-07-13 20:00:27,516 INFO: Reading data for image DSC07652.JPG (queue-size=10
2022-07-13 20:00:27,708 INFO: Extracting ROOT_SIFT_GPU features for image DSC08193.JPG
2022-07-13 20:00:27,963 INFO: Reading data for image DSC07925.JPG (queue-size=10
2022-07-13 20:00:28,017 INFO: Reading data for image DSC07653.JPG (queue-size=11
2022-07-13 20:00:28,024 INFO: Extracting ROOT_SIFT_GPU features for image DSC07649.JPG
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\command_runner.py”, line 38, in command_runner
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\command.py”, line 13, in run
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\detect_features.py”, line 13, in run_impl
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features_processing.py”, line 79, in run_features_processing
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\context.py”, line 58, in parallel_map
self.retrieve()
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features_processing.py”, line 146, in process
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features_processing.py”, line 163, in read_images
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 109, in load_image
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py”, line 1487, in imread
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py”, line 1247, in imread_from_fileobject
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” match_features “C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\opensfm”
2022-07-13 20:00:32,394 INFO: Matching 7742 image pairs
2022-07-13 20:00:32,394 INFO: Computing pair matching with 6 processes
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\match_features.py”, line 13, in run_impl
self.retrieve()
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 318, in load_features
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py”, line 1462, in open
FileNotFoundError: [Errno 2] No such file or directory: ‘C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\opensfm\features\DSC07793.JPG.features.npz’
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\opensfm”
2022-07-13 20:00:33,613 INFO: reading features
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\create_tracks.py”, line 13, in run_impl
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\tracking.py”, line 29, in load_features
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 319, in load_features
return features.FeaturesData.from_file(f, self.config)
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features.py”, line 140, in from_file
s = np.load(fileobject, allow_pickle=False)
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\numpy\lib\npyio.py”, line 432, in load
ret = NpzFile(fid, own_fid=own_fid, allow_pickle=allow_pickle,
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\numpy\lib\npyio.py”, line 189, in init
_zip = zipfile_factory(fid)
File “C:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\numpy\lib\npyio.py”, line 112, in zipfile_factory
return zipfile.ZipFile(file, *args, **kwargs)
File “zipfile.py”, line 1267, in init
File “zipfile.py”, line 1334, in _RealGetContents
zipfile.BadZipFile: File is not a zip file
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\ce02a11f-08f5-43ef-8abf-ca5757968343\opensfm”
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\reconstruct.py”, line 14, in run_impl
File “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py”, line 406, in load_tracks_manager
hmmm… It looks like at least one of the images is corrupted or malformed and it is causing an issue.
Are you able to share the dataset?
Thanks Saijin. I found 5 corrupt images and tossed them. Is there anything else I should be looking for?
I am also having trouble with a multispectral set I flew at the same time but I will post in a different thread.
I will rerun this one and let you know how it goes.
Thanks as always. m
No, nothing I can think of. Do you still have the corrupt ones somewhere? They might be helpful as test data to see if we can do something with broken input images, or maybe to gracefully drop them instead of failing on them.
https://hub.dronedb.app/r/mdk/corrupt-jpgs
Saijin
I put the corrupt ones here.
m
Saijin:
I removed the corrupt images and reran. I am afraid it failed again. The log is too long to attach so I just put some of it in below.
Not sure from that how you tell what it is failing on.
There is plenty of overlap in this set.
It was windy when I flew it so the drone was probably moving a little faster on the downwind legs…
Just groping for an answer to this one.
Did anything change in the online component of this process in the last month?
I have always found webODM to be quite forgiving on alignment issues.
Please let me know what you think.
m
2022-07-18 09:08:25,130 DEBUG: No segmentation for IMG_0131_1.tif, no features masked.
2022-07-18 09:08:25,329 DEBUG: No segmentation for IMG_0809_1.tif, no features masked.
2022-07-18 09:08:25,345 DEBUG: Matching IMG_1039_1.tif and IMG_1177_1.tif. Matcher: FLANN (symmetric) T-desc: 5.309 Matches: FAILED
2022-07-18 09:08:25,350 DEBUG: Matching IMG_0298_1.tif and IMG_0280_1.tif. Matcher: FLANN (symmetric) T-desc: 5.814 Matches: FAILED
2022-07-18 09:08:25,520 DEBUG: No segmentation for IMG_1524_1.tif, no features masked.
2022-07-18 09:08:25,523 DEBUG: No segmentation for IMG_0172_1.tif, no features masked.
2022-07-18 09:08:25,834 DEBUG: No segmentation for IMG_0696_1.tif, no features masked.
2022-07-18 09:08:25,840 DEBUG: Matching IMG_0135_1.tif and IMG_0033_1.tif. Matcher: FLANN (symmetric) T-desc: 5.959 T-robust: 0.002 T-total: 5.961 Matches: 108 Robust: 91 Success: True
2022-07-18 09:08:25,868 DEBUG: No segmentation for IMG_1166_1.tif, no features masked.
2022-07-18 09:08:25,956 DEBUG: No segmentation for IMG_1230_1.tif, no features masked.
2022-07-18 09:08:26,116 DEBUG: Matching IMG_1392_1.tif and IMG_1371_1.tif. Matcher: FLANN (symmetric) T-desc: 6.239 T-robust: 0.001 T-total: 6.241 Matches: 35 Robust: 28 Success: True
2022-07-18 09:08:26,137 DEBUG: Matching IMG_1427_1.tif and IMG_1337_1.tif. Matcher: FLANN (symmetric) T-desc: 5.594 T-robust: 0.002 T-total: 5.600 Matches: 100 Robust: 87 Success: True
2022-07-18 09:08:26,307 DEBUG: Matching IMG_0837_1.tif and IMG_0968_1.tif. Matcher: FLANN (symmetric) T-desc: 6.714 Matches: FAILED
2022-07-18 09:08:26,316 DEBUG: No segmentation for IMG_0148_1.tif, no features masked.
2022-07-18 09:08:26,425 DEBUG: Matching IMG_1783_1.tif and IMG_1659_1.tif. Matcher: FLANN (symmetric) T-desc: 6.009 Matches: FAILED
2022-07-18 09:08:26,537 DEBUG: Matching IMG_0677_1.tif and IMG_0582_1.tif. Matcher: FLANN (symmetric) T-desc: 6.624 Matches: FAILED
2022-07-18 09:08:26,557 DEBUG: No segmentation for IMG_1785_1.tif, no features masked.
2022-07-18 09:08:26,560 DEBUG: Matching IMG_1464_1.tif and IMG_1436_1.tif. Matcher: FLANN (symmetric) T-desc: 5.728 T-robust: 0.009 T-total: 5.739 Matches: 93 Robust: 85 Success: True
2022-07-18 09:08:26,575 DEBUG: No segmentation for IMG_0214_1.tif, no features masked.
2022-07-18 09:08:26,845 DEBUG: No segmentation for IMG_1454_1.tif, no features masked.
2022-07-18 09:08:26,925 DEBUG: Matching IMG_0004_1.tif and IMG_0835_1.tif. Matcher: FLANN (symmetric) T-desc: 5.850 Matches: FAILED
2022-07-18 09:08:26,996 DEBUG: No segmentation for IMG_1369_1.tif, no features masked.
2022-07-18 09:08:27,098 DEBUG: No segmentation for IMG_0286_1.tif, no features masked.
2022-07-18 09:08:27,113 DEBUG: Matching IMG_0647_1.tif and IMG_0750_1.tif. Matcher: FLANN (symmetric) T-desc: 5.790 Matches: FAILED
2022-07-18 09:08:27,251 DEBUG: Matching IMG_1636_1.tif and IMG_1671_1.tif. Matcher: FLANN (symmetric) T-desc: 6.186 Matches: FAILED
2022-07-18 09:08:27,271 DEBUG: No segmentation for IMG_0019_1.tif, no features masked.
2022-07-18 09:08:27,288 DEBUG: No segmentation for IMG_1142_1.tif, no features masked.
2022-07-18 09:08:27,413 DEBUG: Matching IMG_0723_1.tif and IMG_0724_1.tif. Matcher: FLANN (symmetric) T-desc: 6.252 T-robust: 0.003 T-total: 6.256 Matches: 180 Robust: 163 Success: True
2022-07-18 09:08:27,474 DEBUG: Matching IMG_0395_1.tif and IMG_0398_1.tif. Matcher: FLANN (symmetric) T-desc: 5.345 T-robust: 0.004 T-total: 5.353 Matches: 185 Robust: 175 Success: True
2022-07-18 09:08:27,663 DEBUG: No segmentation for IMG_1346_1.tif, no features masked.
2022-07-18 09:08:27,805 DEBUG: No segmentation for IMG_1347_1.tif, no features masked.
2022-07-18 09:08:27,960 DEBUG: Matching IMG_1610_1.tif and IMG_1609_1.tif. Matcher: FLANN (symmetric) T-desc: 6.234 T-robust: 0.002 T-total: 6.239 Matches: 537 Robust: 516 Success: True
2022-07-18 09:08:28,313 DEBUG: Matching IMG_0262_1.tif and IMG_0180_1.tif. Matcher: FLANN (symmetric) T-desc: 6.561 Matches: FAILED
2022-07-18 09:08:28,413 DEBUG: No segmentation for IMG_1143_1.tif, no features masked.
2022-07-18 09:08:28,430 DEBUG: Matching IMG_1194_1.tif and IMG_1297_1.tif. Matcher: FLANN (symmetric) T-desc: 6.059 T-robust: 0.007 T-total: 6.069 Matches: 31 Robust: 20 Success: True
2022-07-18 09:08:28,582 DEBUG: No segmentation for IMG_1394_1.tif, no features masked.
2022-07-18 09:08:28,685 DEBUG: No segmentation for IMG_1504_1.tif, no features masked.
2022-07-18 09:08:28,701 DEBUG: Matching IMG_0827_1.tif and IMG_0829_1.tif. Matcher: FLANN (symmetric) T-desc: 6.884 T-robust: 0.002 T-total: 6.887 Matches: 98 Robust: 77 Success: True
2022-07-18 09:08:28,788 DEBUG: Matching IMG_1418_1.tif and IMG_1344_1.tif. Matcher: FLANN (symmetric) T-desc: 6.945 T-robust: 0.002 T-total: 6.949 Matches: 39 Robust: 30 Success: True
2022-07-18 09:08:28,830 DEBUG: No segmentation for IMG_1201_1.tif, no features masked.
2022-07-18 09:08:28,945 DEBUG: No segmentation for IMG_0260_1.tif, no features masked.
2022-07-18 09:08:28,993 DEBUG: No segmentation for IMG_1197_1.tif, no features masked.
2022-07-18 09:08:29,054 DEBUG: Matching IMG_0102_1.tif and IMG_0114_1.tif. Matcher: FLANN (symmetric) T-desc: 6.296 Matches: FAILED
2022-07-18 09:08:29,087 DEBUG: No segmentation for IMG_0316_1.tif, no features masked.
2022-07-18 09:08:29,184 DEBUG: No segmentation for IMG_0190_1.tif, no features masked.
2022-07-18 09:08:29,214 DEBUG: Matching IMG_0171_1.tif and IMG_0032_1.tif. Matcher: FLANN (symmetric) T-desc: 6.252 T-robust: 0.005 T-total: 6.260 Matches: 55 Robust: 41 Success: True
2022-07-18 09:08:29,226 DEBUG: Matching IMG_1022_1.tif and IMG_0921_1.tif. Matcher: FLANN (symmetric) T-desc: 6.540 T-robust: 0.028 T-total: 6.570 Matches: 21 Robust: 9 Success: False
2022-07-18 09:08:29,383 DEBUG: No segmentation for IMG_0054_1.tif, no features masked.
2022-07-18 09:08:29,395 DEBUG: No segmentation for IMG_0008_1.tif, no features masked.
2022-07-18 09:08:29,504 DEBUG: Matching IMG_0085_1.tif and IMG_0108_1.tif. Matcher: FLANN (symmetric) T-desc: 6.348 Matches: FAILED
2022-07-18 09:08:29,544 DEBUG: Matching IMG_1578_1.tif and IMG_1457_1.tif. Matcher: FLANN (symmetric) T-desc: 6.185 T-robust: 0.007 T-total: 6.197 Matches: 27 Robust: 17 Success: False
2022-07-18 09:08:29,575 DEBUG: Matching IMG_0113_1.tif and IMG_0055_1.tif. Matcher: FLANN (symmetric) T-desc: 6.956 Matches: FAILED
2022-07-18 09:08:29,620 DEBUG: No segmentation for IMG_0732_1.tif, no features masked.
2022-07-18 09:08:29,687 DEBUG: Matching IMG_0118_1.tif and IMG_0186_1.tif. Matcher: FLANN (symmetric) T-desc: 6.663 Matches: FAILED
2022-07-18 09:08:29,849 DEBUG: No segmentation for IMG_0170_1.tif, no features masked.
2022-07-18 09:08:29,935 DEBUG: No segmentation for IMG_0341_1.tif, no features masked.
2022-07-18 09:08:29,993 DEBUG: Matching IMG_1105_1.tif and IMG_1242_1.tif. Matcher: FLANN (symmetric) T-desc: 6.870 Matches: FAILED
2022-07-18 09:08:30,164 DEBUG: No segmentation for IMG_1325_1.tif, no features masked.
2022-07-18 09:08:30,342 DEBUG: Matching IMG_1652_1.tif and IMG_1522_1.tif. Matcher: FLANN (symmetric) T-desc: 6.570 Matches: FAILED
2022-07-18 09:08:30,450 DEBUG: No segmentation for IMG_1089_1.tif, no features masked.
2022-07-18 09:08:30,670 DEBUG: Matching IMG_1192_1.tif and IMG_1052_1.tif. Matcher: FLANN (symmetric) T-desc: 6.382 Matches: FAILED
2022-07-18 09:08:30,773 DEBUG: No segmentation for IMG_0788_1.tif, no features masked.
2022-07-18 09:08:30,841 DEBUG: Matching IMG_0126_1.tif and IMG_0105_1.tif. Matcher: FLANN (symmetric) T-desc: 6.757 Matches: FAILED
2022-07-18 09:08:30,860 DEBUG: Matching IMG_0852_1.tif and IMG_0955_1.tif. Matcher: FLANN (symmetric) T-desc: 6.837 Matches: FAILED
2022-07-18 09:08:30,999 DEBUG: No segmentation for IMG_1761_1.tif, no features masked.
2022-07-18 09:08:31,094 DEBUG: No segmentation for IMG_1685_1.tif, no features masked.
2022-07-18 09:08:31,259 DEBUG: Matching IMG_0111_1.tif and IMG_0056_1.tif. Matcher: FLANN (symmetric) T-desc: 7.237 T-robust: 0.010 T-total: 7.248 Matches: 24 Robust: 14 Success: False
2022-07-18 09:08:31,329 DEBUG: Matching IMG_0611_1.tif and IMG_0516_1.tif. Matcher: FLANN (symmetric) T-desc: 7.089 Matches: FAILED
2022-07-18 09:08:31,342 DEBUG: Matching IMG_0833_1.tif and IMG_0968_1.tif. Matcher: FLANN (symmetric) T-desc: 7.037 Matches: FAILED
2022-07-18 09:08:31,371 DEBUG: Matching IMG_0006_1.tif and IMG_0696_1.tif. Matcher: FLANN (symmetric) T-desc: 6.019 Matches: FAILED
2022-07-18 09:08:31,380 DEBUG: No segmentation for IMG_1028_1.tif, no features masked.
2022-07-18 09:08:31,539 DEBUG: No segmentation for IMG_1552_1.tif, no features masked.
2022-07-18 09:08:31,605 DEBUG: Matching IMG_1155_1.tif and IMG_1159_1.tif. Matcher: FLANN (symmetric) T-desc: 7.056 Matches: FAILED
2022-07-18 09:08:31,620 DEBUG: No segmentation for IMG_1446_1.tif, no features masked.
2022-07-18 09:08:31,653 DEBUG: Matching IMG_0844_1.tif and IMG_0840_1.tif. Matcher: FLANN (symmetric) T-desc: 7.484 Matches: FAILED
2022-07-18 09:08:31,861 DEBUG: No segmentation for IMG_1550_1.tif, no features masked.
2022-07-18 09:08:31,927 DEBUG: No segmentation for IMG_0084_1.tif, no features masked.
2022-07-18 09:08:31,949 DEBUG: Matching IMG_1651_1.tif and IMG_1524_1.tif. Matcher: FLANN (symmetric) T-desc: 7.200 Matches: FAILED
2022-07-18 09:08:31,955 DEBUG: No segmentation for IMG_0304_1.tif, no features masked.
2022-07-18 09:08:31,967 DEBUG: No segmentation for IMG_1453_1.tif, no features masked.
2022-07-18 09:08:32,097 DEBUG: Matching IMG_0131_1.tif and IMG_0172_1.tif. Matcher: FLANN (symmetric) T-desc: 7.353 T-robust: 0.004 T-total: 7.360 Matches: 53 Robust: 42 Success: True
2022-07-18 09:08:32,195 DEBUG: No segmentation for IMG_0409_1.tif, no features masked.
2022-07-18 09:08:32,272 DEBUG: No segmentation for IMG_0334_1.tif, no features masked.
2022-07-18 09:08:32,330 DEBUG: Matching IMG_1050_1.tif and IMG_1166_1.tif. Matcher: FLANN (symmetric) T-desc: 6.950 T-robust: 0.030 T-total: 6.982 Matches: 28 Robust: 12 Success: False
2022-07-18 09:08:32,337 DEBUG: Matching IMG_0809_1.tif and IMG_0810_1.tif. Matcher: FLANN (symmetric) T-desc: 7.357 T-robust: 0.008 T-total: 7.367 Matches: 62 Robust: 47 Success: True
2022-07-18 09:08:32,353 DEBUG: No segmentation for IMG_1443_1.tif, no features masked.
2022-07-18 09:08:32,370 DEBUG: Matching IMG_1230_1.tif and IMG_1121_1.tif. Matcher: FLANN (symmetric) T-desc: 6.527 Matches: FAILED
2022-07-18 09:08:32,510 DEBUG: No segmentation for IMG_0376_1.tif, no features masked.
2022-07-18 09:08:32,568 DEBUG: Matching IMG_0921_1.tif and IMG_0887_1.tif. Matcher: FLANN (symmetric) T-desc: 5.996 T-robust: 0.007 T-total: 6.004 Matches: 20 Robust: 14 Success: False
2022-07-18 09:08:32,575 DEBUG: Matching IMG_0076_1.tif and IMG_0225_1.tif. Matcher: FLANN (symmetric) T-desc: 7.575 Matches: FAILED
2022-07-18 09:08:32,581 DEBUG: No segmentation for IMG_0766_1.tif, no features masked.
2022-07-18 09:08:32,601 DEBUG: No segmentation for IMG_1701_1.tif, no features masked.
2022-07-18 09:08:32,810 DEBUG: Matching IMG_0148_1.tif and IMG_0013_1.tif. Matcher: FLANN (symmetric) T-desc: 6.672 Matches: FAILED
2022-07-18 09:08:32,906 DEBUG: No segmentation for IMG_1059_1.tif, no features masked.
2022-07-18 09:08:32,947 DEBUG: Matching IMG_1785_1.tif and IMG_1658_1.tif. Matcher: FLANN (symmetric) T-desc: 6.639 Matches: FAILED
2022-07-18 09:08:33,011 DEBUG: Matching IMG_1454_1.tif and IMG_1580_1.tif. Matcher: FLANN (symmetric) T-desc: 6.447 T-robust: 0.016 T-total: 6.467 Matches: 29 Robust: 20 Success: True
2022-07-18 09:08:33,028 DEBUG: Matching IMG_1142_1.tif and IMG_1003_1.tif. Matcher: FLANN (symmetric) T-desc: 5.915 Matches: FAILED
2022-07-18 09:08:33,185 DEBUG: Matching IMG_1391_1.tif and IMG_1369_1.tif. Matcher: FLANN (symmetric) T-desc: 6.744 T-robust: 0.010 T-total: 6.758 Matches: 43 Robust: 30 Success: True
2022-07-18 09:08:33,274 DEBUG: Matching IMG_0286_1.tif and IMG_0019_1.tif. Matcher: FLANN (symmetric) T-desc: 6.333 T-robust: 0.010 T-total: 6.346 Matches: 64 Robust: 54 Success: True
2022-07-18 09:08:33,324 DEBUG: Matching IMG_0224_1.tif and IMG_0214_1.tif. Matcher: FLANN (symmetric) T-desc: 7.208 Matches: FAILED
2022-07-18 09:08:33,354 DEBUG: No segmentation for IMG_1055_1.tif, no features masked.
2022-07-18 09:08:33,394 DEBUG: No segmentation for IMG_1403_1.tif, no features masked.
2022-07-18 09:08:33,397 DEBUG: No segmentation for IMG_1199_1.tif, no features masked.
2022-07-18 09:08:33,442 DEBUG: No segmentation for IMG_0294_1.tif, no features masked.
2022-07-18 09:08:33,446 DEBUG: Matching IMG_1030_1.tif and IMG_0905_1.tif. Matcher: FLANN (symmetric) T-desc: 6.031 Matches: FAILED
2022-07-18 09:08:33,524 DEBUG: Matching IMG_0146_1.tif and IMG_0136_1.tif. Matcher: FLANN (symmetric) T-desc: 6.269 Matches: FAILED
2022-07-18 09:08:33,632 DEBUG: No segmentation for IMG_1338_1.tif, no features masked.
2022-07-18 09:08:33,663 DEBUG: No segmentation for IMG_1634_1.tif, no features masked.
2022-07-18 09:08:33,710 DEBUG: Matching IMG_1460_1.tif and IMG_1458_1.tif. Matcher: FLANN (symmetric) T-desc: 5.726 T-robust: 0.020 T-total: 5.749 Matches: 81 Robust: 68 Success: True
2022-07-18 09:08:33,796 DEBUG: Matching IMG_0004_1.tif and IMG_0008_1.tif. Matcher: FLANN (symmetric) T-desc: 4.561 T-robust: 0.013 T-total: 4.579 Matches: 144 Robust: 134 Success: True
2022-07-18 09:08:33,860 DEBUG: No segmentation for IMG_1497_1.tif, no features masked.
2022-07-18 09:08:33,864 DEBUG: No segmentation for IMG_1195_1.tif, no features masked.
2022-07-18 09:08:33,918 DEBUG: No segmentation for IMG_1415_1.tif, no features masked.
2022-07-18 09:08:33,976 DEBUG: Matching IMG_1346_1.tif and IMG_1347_1.tif. Matcher: FLANN (symmetric) T-desc: 6.478 T-robust: 0.015 T-total: 6.501 Matches: 687 Robust: 676 Success: True
2022-07-18 09:08:34,091 DEBUG: Matching IMG_1143_1.tif and IMG_1071_1.tif. Matcher: FLANN (symmetric) T-desc: 5.765 T-robust: 0.010 T-total: 5.778 Matches: 23 Robust: 15 Success: False
2022-07-18 09:08:34,184 DEBUG: No segmentation for IMG_0957_1.tif, no features masked.
2022-07-18 09:08:34,247 DEBUG: No segmentation for IMG_1350_1.tif, no features masked.
2022-07-18 09:08:34,331 DEBUG: Matching IMG_1394_1.tif and IMG_1504_1.tif. Matcher: FLANN (symmetric) T-desc: 5.898 Matches: FAILED
2022-07-18 09:08:34,432 DEBUG: No segmentation for IMG_1026_1.tif, no features masked.
2022-07-18 09:08:34,517 DEBUG: Matching IMG_1201_1.tif and IMG_1197_1.tif. Matcher: FLANN (symmetric) T-desc: 5.801 T-robust: 0.014 T-total: 5.816 Matches: 32 Robust: 18 Success: False
2022-07-18 09:08:34,836 DEBUG: Matching IMG_0260_1.tif and IMG_0316_1.tif. Matcher: FLANN (symmetric) T-desc: 6.047 Matches: FAILED
2022-07-18 09:08:34,872 DEBUG: Matching IMG_0190_1.tif and IMG_0054_1.tif. Matcher: FLANN (symmetric) T-desc: 5.816 Matches: FAILED
2022-07-18 09:08:34,947 DEBUG: No segmentation for IMG_0918_1.tif, no features masked.
2022-07-18 09:08:35,193 DEBUG: Matching IMG_1691_1.tif and IMG_1752_1.tif. Matcher: FLANN (symmetric) T-desc: 5.647 Matches: FAILED
2022-07-18 09:08:35,276 DEBUG: Matching IMG_0170_1.tif and IMG_0168_1.tif. Matcher: FLANN (symmetric) T-desc: 5.697 T-robust: 0.001 T-total: 5.699 Matches: 46 Robust: 37 Success: True
2022-07-18 09:08:35,304 DEBUG: Matching IMG_1441_1.tif and IMG_1439_1.tif. Matcher: FLANN (symmetric) T-desc: 5.795 T-robust: 0.002 T-total: 5.799 Matches: 61 Robust: 50 Success: True
2022-07-18 09:08:35,314 DEBUG: No segmentation for IMG_0660_1.tif, no features masked.
2022-07-18 09:08:35,505 DEBUG: No segmentation for IMG_1514_1.tif, no features masked.
2022-07-18 09:08:35,533 DEBUG: No segmentation for IMG_0597_1.tif, no features masked.
2022-07-18 09:08:35,549 DEBUG: Matching IMG_1325_1.tif and IMG_1329_1.tif. Matcher: FLANN (symmetric) T-desc: 5.542 T-robust: 0.009 T-total: 5.553 Matches: 28 Robust: 18 Success: False
2022-07-18 09:08:35,612 DEBUG: No segmentation for IMG_0635_1.tif, no features masked.
2022-07-18 09:08:35,658 DEBUG: No segmentation for IMG_0638_1.tif, no features masked.
2022-07-18 09:08:35,763 DEBUG: No segmentation for IMG_0621_1.tif, no features masked.
2022-07-18 09:08:35,802 DEBUG: Matching IMG_0801_1.tif and IMG_0732_1.tif. Matcher: FLANN (symmetric) T-desc: 6.575 Matches: FAILED
2022-07-18 09:08:35,838 DEBUG: Matching IMG_0341_1.tif and IMG_0235_1.tif. Matcher: FLANN (symmetric) T-desc: 6.141 T-robust: 0.002 T-total: 6.148 Matches: 116 Robust: 100 Success: True
2022-07-18 09:08:35,852 DEBUG: Matching IMG_1761_1.tif and IMG_1685_1.tif. Matcher: FLANN (symmetric) T-desc: 4.985 T-robust: 0.004 T-total: 4.991 Matches: 48 Robust: 38 Success: True
2022-07-18 09:08:35,952 DEBUG: No segmentation for IMG_1206_1.tif, no features masked.
2022-07-18 09:08:36,041 DEBUG: No segmentation for IMG_1160_1.tif, no features masked.
2022-07-18 09:08:36,048 DEBUG: Matching IMG_0924_1.tif and IMG_0788_1.tif. Matcher: FLANN (symmetric) T-desc: 5.377 Matches: FAILED
2022-07-18 09:08:36,158 DEBUG: Matching IMG_0134_1.tif and IMG_0035_1.tif. Matcher: FLANN (symmetric) T-desc: 5.306 T-robust: 0.004 T-total: 5.316 Matches: 90 Robust: 78 Success: True
2022-07-18 09:08:36,246 DEBUG: No segmentation for IMG_0016_1.tif, no features masked.
2022-07-18 09:08:36,246 DEBUG: No segmentation for IMG_0397_1.tif, no features masked.
2022-07-18 09:08:36,345 DEBUG: No segmentation for IMG_1153_1.tif, no features masked.
2022-07-18 09:08:36,390 DEBUG: Matching IMG_1089_1.tif and IMG_0986_1.tif. Matcher: FLANN (symmetric) T-desc: 6.048 Matches: FAILED
2022-07-18 09:08:36,436 DEBUG: Matching IMG_1552_1.tif and IMG_1550_1.tif. Matcher: FLANN (symmetric) T-desc: 5.101 T-robust: 0.003 T-total: 5.105 Matches: 44 Robust: 34 Success: True
2022-07-18 09:08:36,578 DEBUG: No segmentation for IMG_0116_1.tif, no features masked.
2022-07-18 09:08:36,739 DEBUG: Matching IMG_1028_1.tif and IMG_1044_1.tif. Matcher: FLANN (symmetric) T-desc: 5.479 Matches: FAILED
2022-07-18 09:08:37,080 DEBUG: Matching IMG_1446_1.tif and IMG_1453_1.tif. Matcher: FLANN (symmetric) T-desc: 5.705 Matches: FAILED
2022-07-18 09:08:37,188 DEBUG: Matching IMG_0304_1.tif and IMG_0409_1.tif. Matcher: FLANN (symmetric) T-desc: 5.530 T-robust: 0.001 T-total: 5.532 Matches: 108 Robust: 97 Success: True
2022-07-18 09:08:37,255 DEBUG: Matching IMG_0334_1.tif and IMG_0376_1.tif. Matcher: FLANN (symmetric) T-desc: 5.158 Matches: FAILED
2022-07-18 09:08:37,274 DEBUG: Matching IMG_0433_1.tif and IMG_0413_1.tif. Matcher: FLANN (symmetric) T-desc: 5.930 T-robust: 0.001 T-total: 5.932 Matches: 51 Robust: 43 Success: True
2022-07-18 09:08:37,288 DEBUG: Matching IMG_1317_1.tif and IMG_1443_1.tif. Matcher: FLANN (symmetric) T-desc: 5.337 Matches: FAILED
2022-07-18 09:08:37,589 DEBUG: Matching IMG_0084_1.tif and IMG_0221_1.tif. Matcher: FLANN (symmetric) T-desc: 5.982 Matches: FAILED
2022-07-18 09:08:38,075 DEBUG: Matching IMG_0766_1.tif and IMG_0219_1.tif. Matcher: FLANN (symmetric) T-desc: 5.741 Matches: FAILED
2022-07-18 09:08:38,081 DEBUG: Matching IMG_1224_1.tif and IMG_1262_1.tif. Matcher: FLANN (symmetric) T-desc: 5.710 Matches: FAILED
2022-07-18 09:08:38,110 DEBUG: Matching IMG_1701_1.tif and IMG_1744_1.tif. Matcher: FLANN (symmetric) T-desc: 5.768 Matches: FAILED
2022-07-18 09:08:38,328 DEBUG: Matching IMG_0261_1.tif and IMG_0313_1.tif. Matcher: FLANN (symmetric) T-desc: 5.741 T-robust: 0.010 T-total: 5.753 Matches: 21 Robust: 12 Success: False
2022-07-18 09:08:38,403 DEBUG: Matching IMG_0298_1.tif and IMG_0294_1.tif. Matcher: FLANN (symmetric) T-desc: 5.368 T-robust: 0.001 T-total: 5.369 Matches: 33 Robust: 27 Success: True
2022-07-18 09:08:38,416 DEBUG: Matching IMG_1059_1.tif and IMG_1055_1.tif. Matcher: FLANN (symmetric) T-desc: 5.826 T-robust: 0.021 T-total: 5.848 Matches: 22 Robust: 11 Success: False
2022-07-18 09:08:38,477 DEBUG: Matching IMG_1541_1.tif and IMG_1634_1.tif. Matcher: FLANN (symmetric) T-desc: 5.663 Matches: FAILED
2022-07-18 09:08:38,725 DEBUG: Matching IMG_1199_1.tif and IMG_1195_1.tif. Matcher: FLANN (symmetric) T-desc: 5.712 Matches: FAILED
2022-07-18 09:08:38,738 DEBUG: Matching IMG_1746_1.tif and IMG_1740_1.tif. Matcher: FLANN (symmetric) T-desc: 5.458 Matches: FAILED
2022-07-18 09:08:38,803 DEBUG: Matching IMG_1338_1.tif and IMG_1335_1.tif. Matcher: FLANN (symmetric) T-desc: 4.819 T-robust: 0.001 T-total: 4.821 Matches: 125 Robust: 110 Success: True
2022-07-18 09:08:38,873 DEBUG: Matching IMG_0907_1.tif and IMG_0908_1.tif. Matcher: FLANN (symmetric) T-desc: 5.545 T-robust: 0.002 T-total: 5.547 Matches: 298 Robust: 292 Success: True
2022-07-18 09:08:38,956 DEBUG: Matching IMG_0726_1.tif and IMG_0724_1.tif. Matcher: FLANN (symmetric) T-desc: 5.240 Matches: FAILED
2022-07-18 09:08:38,976 DEBUG: Matching IMG_1403_1.tif and IMG_1497_1.tif. Matcher: FLANN (symmetric) T-desc: 6.008 T-robust: 0.019 T-total: 6.027 Matches: 25 Robust: 10 Success: False
2022-07-18 09:08:38,980 DEBUG: Matching IMG_1658_1.tif and IMG_1788_1.tif. Matcher: FLANN (symmetric) T-desc: 5.448 Matches: FAILED
2022-07-18 09:08:38,987 DEBUG: Matching IMG_1338_1.tif and IMG_1425_1.tif. Matcher: FLANN (symmetric) T-desc: 5.800 T-robust: 0.001 T-total: 5.801 Matches: 93 Robust: 81 Success: True
2022-07-18 09:08:39,095 DEBUG: Matching IMG_1059_1.tif and IMG_1060_1.tif. Matcher: FLANN (symmetric) T-desc: 4.996 T-robust: 0.001 T-total: 4.997 Matches: 191 Robust: 174 Success: True
2022-07-18 09:08:39,239 DEBUG: Matching IMG_0957_1.tif and IMG_1092_1.tif. Matcher: FLANN (symmetric) T-desc: 5.437 Matches: FAILED
2022-07-18 09:08:39,303 DEBUG: Matching IMG_1026_1.tif and IMG_0915_1.tif. Matcher: FLANN (symmetric) T-desc: 4.951 T-robust: 0.019 T-total: 4.971 Matches: 21 Robust: 10 Success: False
2022-07-18 09:08:39,327 DEBUG: Matching IMG_1415_1.tif and IMG_1350_1.tif. Matcher: FLANN (symmetric) T-desc: 5.877 Matches: FAILED
2022-07-18 09:08:39,328 DEBUG: Matching IMG_0918_1.tif and IMG_0915_1.tif. Matcher: FLANN (symmetric) T-desc: 4.472 T-robust: 0.019 T-total: 4.491 Matches: 28 Robust: 14 Success: False
2022-07-18 09:08:39,349 DEBUG: Matching IMG_0047_1.tif and IMG_0257_1.tif. Matcher: FLANN (symmetric) T-desc: 4.830 Matches: FAILED
2022-07-18 09:08:39,515 DEBUG: Matching IMG_0618_1.tif and IMG_0502_1.tif. Matcher: FLANN (symmetric) T-desc: 4.641 Matches: FAILED
2022-07-18 09:08:39,644 DEBUG: Matching IMG_0761_1.tif and IMG_0635_1.tif. Matcher: FLANN (symmetric) T-desc: 4.367 Matches: FAILED
2022-07-18 09:08:39,645 DEBUG: Matching IMG_1206_1.tif and IMG_1143_1.tif. Matcher: FLANN (symmetric) T-desc: 3.842 Matches: FAILED
2022-07-18 09:08:39,650 DEBUG: Matching IMG_0397_1.tif and IMG_0454_1.tif. Matcher: FLANN (symmetric) T-desc: 3.598 T-robust: 0.001 T-total: 3.599 Matches: 107 Robust: 95 Success: True
2022-07-18 09:08:39,693 DEBUG: Matching IMG_1514_1.tif and IMG_1522_1.tif. Matcher: FLANN (symmetric) T-desc: 4.368 T-robust: 0.019 T-total: 4.387 Matches: 28 Robust: 10 Success: False
2022-07-18 09:08:39,748 DEBUG: Matching IMG_0660_1.tif and IMG_0597_1.tif. Matcher: FLANN (symmetric) T-desc: 4.555 Matches: FAILED
2022-07-18 09:08:39,761 DEBUG: Matching IMG_1436_1.tif and IMG_1437_1.tif. Matcher: FLANN (symmetric) T-desc: 3.368 T-robust: 0.001 T-total: 3.369 Matches: 412 Robust: 398 Success: True
2022-07-18 09:08:39,771 DEBUG: Matching IMG_0638_1.tif and IMG_0621_1.tif. Matcher: FLANN (symmetric) T-desc: 4.220 Matches: FAILED
2022-07-18 09:08:39,773 DEBUG: Matching IMG_1059_1.tif and IMG_1153_1.tif. Matcher: FLANN (symmetric) T-desc: 3.611 Matches: FAILED
2022-07-18 09:08:39,800 DEBUG: Matching IMG_0289_1.tif and IMG_0016_1.tif. Matcher: FLANN (symmetric) T-desc: 3.960 Matches: FAILED
2022-07-18 09:08:39,801 DEBUG: Matching IMG_1160_1.tif and IMG_1187_1.tif. Matcher: FLANN (symmetric) T-desc: 3.946 Matches: FAILED
2022-07-18 09:08:39,819 DEBUG: Matching IMG_0116_1.tif and IMG_0050_1.tif. Matcher: FLANN (symmetric) T-desc: 3.382 Matches: FAILED
2022-07-18 09:08:39,867 INFO: Matched 21239 pairs (perspective-perspective: 21239) in 3196.8747277999996 seconds (0.15051907945760157 seconds/pair).
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\8f89fd29-e9ca-4c80-997c-678a0f01ece1\opensfm”
2022-07-18 09:08:44,363 INFO: reading features
2022-07-18 09:09:40,847 DEBUG: Merging features onto tracks
2022-07-18 09:09:49,168 DEBUG: Good tracks: 387812
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\8f89fd29-e9ca-4c80-997c-678a0f01ece1\opensfm”
2022-07-18 09:10:03,421 INFO: Starting incremental reconstruction
Dear Forum:
I have gone out and flown another mission with a Sony A6000 on auto settings.
It took 96 images or so fine and then a bunch were out of focus and then one was corrupt on the SD card and then 25 or so were out of focus and then back to normal sometimes a corrupt file will appear with no out of focus images on either side of it.
If you look at the file sizes the out of focus ones are only about half the size of the in focus images!
What is going here?
Can it be the speed of the SD card?
Is the SD card faulty? I reformatted it yesterday.
I am running the camera in “Intelligent Auto” mode but this has always been the case.
This has never happened before this last week!
I’ve never overwhelmed a card with stills on a Sony A6000, but if the card is dying (which does happen), it will start to lose data. Definitely worth trying another card.
I am processing a dataset with 936 images. I tried it on a 20 core windows server and it has been running for two days with no result yet!
I have looked through all the images and they look great.
Below is an example of the verbose messages I am getting while it processes.
Is this message normal or bad?
2022-07-29 09:18:35,014 DEBUG: Matching DSC01320.JPG and DSC01042.JPG. Matcher: FLANN (symmetric) T-desc: 1.153 T-robust: 0.013 T-total: 1.165 Matches: 23 Robust: 9 Success: False
2022-07-29 09:18:35,552 DEBUG: Matching DSC00909.JPG and DSC00788.JPG. Matcher: FLANN (symmetric) T-desc: 1.458 T-robust: 0.014 T-total: 1.472 Matches: 31 Robust: 10 Success: False
2022-07-29 09:18:35,598 DEBUG: Matching DSC01103.JPG and DSC00780.JPG. Matcher: FLANN (symmetric) T-desc: 1.157 T-robust: 0.013 T-total: 1.170 Matches: 26 Robust: 9 Success: False
What are your processing settings?
I have tried a few. Just running now with defaults and it is into 24 hours!
When I’ve processed ~1000 20MPx photos on my server with 512GB RAM and dual 20-core CPUs, using CPU only (no GPU) it’s taken around 3.5 hours with default settings, typically using up to ~50GB RAM and ~50GB disk space.
What are your machine details (RAM, swap, disk, etc)?
Can you monitor how much of the available RAM it is consuming?
Its a Dell server with Xeon 20 core 2.6 Ghz processor with 128GB of RAM and 21 TB of storage.
Can’t be running out of resources I wouldn’t think.
I really wanted to know if the Success: False message message at the end of this log strings is a flag of a failure of some kind.
Is it?
No it isn’t. It just means that 20 or more robust matched points were not found.
However, if this makes up the majority of your attempted matches, then you need to increase the number of features detected. I note that the initial matches numbers are quite low, in the 20s, what about for adjacent images, how do the numbers look there? Often in adjacent images with high overlap I see thousands to tens of thousands, sometimes around 100000 matches.
Thanks Gordon.
It is a forested area shot from 85 meters and 80% overlap. The images themselves look great but I think it is having trouble matching with the varying aspect of the trees as it flies over. Does that sound right to you? What are my best settings for this situation? I shot with Micasense and RGB Sony A6000 in the same flight and both solutions are having problems matching it appears. Some of the mosaic resolves great but some of the overlap paths have blurs and swirls in them.
Have you got a set of settings best suited for this?
I have same problem, but I have processed and I have obtained the risult, aftere this I have setted the GCP poin and I have got the problem, what can I do to risolve the problem. With the same picture zephir free obtain a good result
Was it windy when you took the images? Dense canopies with wind is a poor combination, as there will be very few common features between images. The changing aspect of the trees as you fly over is a good thing for building the point cloud, but as mentioned above, wind can make things very difficult.
