I’m new to WebODM. I have collected images for 65ac. (260 RGB images). 80% front overlap and 70% side. I have tried various settings (fast ortho, high resolution) and the job fails with the error. I have been able to process some smaller datasets including a sub set of the one I’m trying to process. Suggestions?
Thanks!
System: W10, 8GB RAM, 120GB free disk
Data: Montair.zip - Google Drive
Output:
[INFO] Writing ODM 2.5D Mesh file in: C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\odm_25dmesh.ply
[INFO] ODM 2.5D DSM resolution: 0.22785000000000002
[INFO] Created temporary directory: C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp
[INFO] running pdal info “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_filterpoints\point_cloud.ply” > “C:\Users\mspiess\AppData\Local\Temp\tmpnvqea9vh.json”
[INFO] Point cloud bounds are [minx: -335.0365295, maxx: 543.3630371] [miny: -460.828186, maxy: 311.4981079]
[INFO] DEM resolution is (3390, 3856), max tile size is 4096, will split DEM generation into 1 tiles
[INFO] Generating C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\mesh_dsm_r0.6444571203734195_x0_y0.tif (max, radius: 0.6444571203734195, resolution: 0.22785000000000002)
[INFO] running pdal pipeline -i C:\Users\mspiess\AppData\Local\Temp\tmp248kpiv8.json
[INFO] running gdalbuildvrt -input_file_list “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles_list.txt” “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.vrt”
[INFO] running gdal_translate -co NUM_THREADS=4 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 22.4% “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.tmp.tif”
Input file size is 3856, 3390
[INFO] running gdal_translate -co NUM_THREADS=4 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 22.4% -outsize 10% 0 “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.tmp.tif” “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.small.tif”
0
10
20
30
40
50
60
70
80
90
[INFO] running gdalbuildvrt -resolution highest -r bilinear “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\merged.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.small_filled.tif” “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.tmp.tif”
[INFO] running gdal_translate -co NUM_THREADS=4 -co TILED=YES -co BIGTIFF=IF_SAFER -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 22.4% “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\merged.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\tiles.tif”
[INFO] Completed mesh_dsm.tif in 0:00:05.688173
[INFO] Sampling points from DSM: C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\mesh_dsm.tif
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\dem2points” -inputFile “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\mesh_dsm.tif” -outputFile “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\dsm_points.ply” -skirtHeightThreshold 1.5 -skirtIncrements 0.2 -skirtHeightCap 100
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\PoissonRecon” --in “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\dsm_points.ply” --out “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\odm_25dmesh.dirty.ply” --depth 11 --pointWeight 4 --samplesPerNode 1.0 --threads 3 --maxMemory 2 --bType 2 --linearFit
[WARNING] Child returned 3221225477
[WARNING] PoissonRecon failed with 1 threads, let’s retry with 0…
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\PoissonRecon” --in “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\tmp\dsm_points.ply” --out “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\odm_25dmesh.dirty.ply” --depth 11 --pointWeight 4 --samplesPerNode 1.0 --threads 1 --maxMemory 2 --bType 2 --linearFit
[WARNING] Child returned 3221226505
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\ReconstructMesh” -i “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\odm_25dmesh.dirty.ply” -o “C:\WebODM\resources\app\apps\NodeODM\data\753ed0e7-07c9-4a2b-b031-9affb0f3d737\odm_meshing\odm_25dmesh.ply” --remove-spikes 0 --remove-spurious 20 --smooth 0 --target-face-num 400000
Child returned 1
File “C:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 89, in execute
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 340, in run
[Previous line repeated 2 more times]
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 321, in run
File “C:\WebODM\resources\app\apps\ODM\stages\odm_meshing.py”, line 66, in process
mesh.create_25dmesh(tree.filtered_point_cloud, tree.odm_25dmesh,
File “C:\WebODM\resources\app\apps\ODM\opendm\mesh.py”, line 43, in create_25dmesh
mesh = screened_poisson_reconstruction(dsm_points, outMesh, depth=depth,
File “C:\WebODM\resources\app\apps\ODM\opendm\mesh.py”, line 207, in screened_poisson_reconstruction
system.run(’"{reconstructmesh}" -i “{infile}” ’
File “C:\WebODM\resources\app\apps\ODM\opendm\system.py”, line 106, in run
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying.html
100 - done.
