I am trying to upload a .csv delimited GCP file for a test project but after a few attempts I keep getting this message: Cannot upload Leigh Park WebODM.csv, exceeded max retries (10),
I can process the model without the GCP’s but it won’t let me add them retrospectively either. How do I get around this issue?
I only found one other topic with this error in the forum and it has not been answered.
Apologies as I am a new user the forum does not allow me to upload the file. I will however copy paste it’s content into this response sir. Apologies for how it looks but the values all sit underneath the respective headers for GCP Label, Y, X and Z. I will also try and obtain a screencapture of the error message I get and post that as a response to this thread.
GCP Label Y X Z
1 150460.712 386185.801 68.121
2 150433.74 386175.802 67.879
3 150421.51 386219.891 68.644
4 150460.046 386214.878 68.148
5 150458.326 386199.733 68.505
6 150476.712 386198.077 68.452
7 150441.208 386212.772 68.636
B 150450.116 386185.85 68.012
If the above text you pasted represents exactly what is in your CSV, it makes sense the upload fails as it is not a traditional comma-separated CSV, but instead space-separated/delimited.
Thanks makes sense, North pole? It seems as though my X and Y values swapped round in the conversion from WGS84 to EPSG:27700 (OSGB36). Much appreciated. Will probably use the GCP editor in WebODM to make a GCP file that way I can be certain it will work.
