Cannot Launch WebODM Exceeded Max Retries
Hello i purchased the Windows installer 1.9.15 build 68, my sistem is Win 10 64 bit
I have Install/Unistall Reboot and Install on another disk but with same result
in Firewall setting i add the app in the list with checked private and public.
Disk as 202 GB free
“Booting WebODM 1.9.15 build 68…”
“Trying to connect to NodeODM localhost:29301…”
“nodeodm: error: Cannot read list of options from ODM (from temporary file). Is ODM installed in F:\WebODM\resources\app\apps\ODM?\r\n”
“nodeodm: exited with code 1”
“(node:3840) UnhandledPromiseRejectionWarning: Error: Exit code: 1\n at ChildProcess. (F:\WebODM\resources\app\utils.js:63:19)\n at ChildProcess.emit (events.js:210:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”
“(node:3840) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)”
“(node:3840) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.”
“Attempt 0 failed, retrying…”
“Attempt 1 failed, retrying…”
“Attempt 2 failed, retrying…”
“Attempt 3 failed, retrying…”
“Attempt 4 failed, retrying…”
“Attempt 5 failed, retrying…”
“Attempt 6 failed, retrying…”
“Attempt 7 failed, retrying…”
“Attempt 8 failed, retrying…”
“Attempt 9 failed, retrying…”
“Attempt 10 failed, retrying…”
“Attempt 11 failed, retrying…”
“Attempt 12 failed, retrying…”
“Attempt 13 failed, retrying…”
“Attempt 14 failed, retrying…”
Did you try rebooting your computer? That fixes this problem for me.
I am suddenly getting this same error?
I rebooted and it is still happening, it was working just 2 weeks ago when I last ran it.
System Specs:
Win 10 pro
Intel i9-9900k 3.6 Ghz
64 GB Ram (56 avail)
Disk Free 595GB
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: Initialized 3 tasks\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: Found orphaned directory: 7d2362ae-da02-4038-a75d-5c71924b20fd, removing…\r\n”
“nodeodm: error: EPERM: operation not permitted, unlink ‘D:\WebODM\resources\app\apps\NodeODM\data\7d2362ae-da02-4038-a75d-5c71924b20fd\images\DJI_0696.JPG’\r\n”
“(node:14016) UnhandledPromiseRejectionWarning: Error: Exit code: 1\n at ChildProcess. (D:\WebODM\resources\app\utils.js:63:19)\n at ChildProcess.emit (events.js:210:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”
“(node:14016) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)”
“(node:14016) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.”
Okay I figured it out.
I noticed this part referencing the orphaned directory
So I just went in and renamed with a .old on each directory there.
(not sure if this image will work?)
Once I did that, the app launched without an issue.
If there is nothing you need in those task directories, you could delete them.
Good to know. I was unsure so I just renamed them for now.
