Cannot find parameter "texturing-nadir-weight" in WebODM
Good morning,
I want to congratulate you all for the excellent software.
I was unable to locate the “texturing-nadir-weight” parameter.
I use Windows 7 and did the manual installation.
API Version: 1.5.3 / Engine(version): odm(0.9.1).
Via Git Bash I tried the following commands:
  1. “docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml down”
  2. ./webodm.sh update
I already deleted the WebODM folder and through the GIT GUI I performed the “Clone Existing Repository” again.
I searched for the text “texturing-nadir-weight” in all the files in the WebODM folder and found it only in the file “D: \ WebODM \ nodeodm \ external \ NodeODM \ tests \ odm_options.json”
How can I manually add this option in WebODM?
Thank you for all,
Cláudio
Good news, that parameter has been removed; the texturing algorithm already chooses the best view without tweaking of parameters!
Thank you very much for the reply.
What other parameter can I use to improve the appearance of the roof edges?
pc-quality probably has the the most impact; make sure it’s set to high. Flying at higher elevation helps a lot also.
