Cannot download task, task status is TaskStatus.RUNNING
I use lightning server to do 5xx photo, but it stuck with this message
Image Resize / Upload
And the last position on console is
Whole texturing procedure took: 155.17s
[DEBUG] Writing MVS Textured file in: /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_texturing_25d/odm_textured_model.obj
[DEBUG] running /code/SuperBuild/install/bin/texrecon /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/opensfm/reconstruction.nvm /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_meshing/odm_25dmesh.ply /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_texturing_25d/odm_textured_model -d gmi -o gauss_clamping -t none --nadir_mode -n 65535
/code/SuperBuild/install/bin/texrecon (built on Apr 24 2019, 00:27:44)
Load and prepare mesh:
Reading PLY: 100000 verts…
199318 faces…
done.
Warning: Zero-length normals detected: 5 face normals, 0 vertex normals
Generating texture views:
NVM: Loading file…
NVM: Number of features: 0
Loading 100%… done. (Took 25.99s)
Building adjacency graph:
Adding edges 100%… done. (Took 0.459s)
298633 total edges.
View selection:
Building BVH from 199318 faces…
done. (Took: 310 ms)
Calculating face qualities 100%… done. (Took 16.554s)
Postprocessing face infos 100%… done. (Took 1.094s)
Maximum quality of a face within an image: 4876.29
Clamping qualities to 582.288 within normalization.
Writing data cost file…
done.
Optimizing:
Time[s] Energy
0 191794
1 190354
1 185579
2 183104
2 181930
3 181199
3 180795
4 180574
4 180350
4 180171
5 180069
5 179986
6 179930
6 179874
6 179821
3489 faces have not been seen
Took: 25.619s
Generating texture patches:
Running…
done. (Took 5.249s)
2202 texture patches.
Running global seam leveling:
done.
Lhs dimensionality: 117304 x 117304
Calculating adjustments:
Color channel 0: CG took 100 iterations. Residual is 7.86312e-05
Color channel 1: CG took 100 iterations. Residual is 8.21635e-05
Color channel 2: CG took 103 iterations. Residual is 9.94243e-05
Took 0.316 seconds
Adjusting texture patches 100%… done. (Took 1.677s)
Running local seam leveling:
Blending texture patches 100%… done. (Took 34.582s)
Generating texture atlases:
Sorting texture patches…
done.
Working on atlas 8 100%… done.
Finalizing texture atlases…
done. (Took: 11.963s)
Building objmodel:
Saving model…
done.
Whole texturing procedure took: 121.057s
[INFO] Running georeferencing with OpenSfM transformation matrix
[DEBUG] running /code/build/bin/odm_georef -bundleFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/opensfm/bundle_r000.out -inputTransformFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/opensfm/geocoords_transformation.txt -inputCoordFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/coords.txt -inputFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_texturing_25d/odm_textured_model.obj -outputFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_texturing_25d/odm_textured_model_geo.obj -inputPointCloudFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_filterpoints/point_cloud.ply -outputPointCloudFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz -outputPointCloudSrs ‘+proj=utm +zone=47 +datum=WGS84 +units=m +no_defs’ -logFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_25dgeoreferencing/odm_georeferencing_log.txt -outputTransformFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_25dgeoreferencing/odm_georeferencing_transform.txt -georefFileOutputPath /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_25dgeoreferencing/odm_georeferencing_model_geo.txt
[INFO] Calculating cropping area and generating bounds shapefile from point cloud
[DEBUG] running pdal translate -i “/var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz” -o “/var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.filtered.las” decimation outlier range --filters.decimation.step=90 --filters.outlier.method=radius --filters.outlier.radius=2 --filters.outlier.min_k=2 --filters.range.limits=‘Classification![7:7]’
[DEBUG] running pdal info --boundary --filters.hexbin.edge_length=1 --filters.hexbin.threshold=0 /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.filtered.las > /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.boundary.json
[DEBUG] running pdal info --summary /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz > /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.summary.json
[DEBUG] running ogr2ogr -overwrite -a_srs “+proj=utm +zone=47 +datum=WGS84 +units=m +no_defs” /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.bounds.shp /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.bounds.geojson
[DEBUG] running /code/build/bin/odm_georef -bundleFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/opensfm/bundle_r000.out -inputTransformFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/opensfm/geocoords_transformation.txt -inputCoordFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/coords.txt -inputFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_texturing/odm_textured_model.obj -outputFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_texturing/odm_textured_model_geo.obj -logFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferencing_log.txt -outputTransformFile /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferencing_transform.txt -georefFileOutputPath /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferencing_model_geo.txt
[INFO] Running ODM Georeferencing Cell - Finished
[INFO] Running ODM DEM Cell
[INFO] Classify: True
[INFO] Create DSM: True
[INFO] Create DTM: True
[INFO] DEM input file /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz found: True
[INFO] Classifying /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz using Simple Morphological Filter
[DEBUG] running pdal translate -i /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz -o /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz smrf --filters.smrf.scalar=1.25 --filters.smrf.slope=0.15 --filters.smrf.threshold=0.5 --filters.smrf.window=18.0
[INFO] Created …/var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz in 0:01:58.119820
[DEBUG] running pdal info --summary /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_georeferencing/odm_georeferenced_model.laz > /tmp/tmpXLaZ2t.json
[INFO] Point cloud bounds are [minx: 723352.6, maxx: 723659.94] [miny: 1613780.61, maxy: 1614053.69]
[INFO] DEM resolution is (6147, 5462), max tile size is 2048, will split DEM generation into 16 tiles
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x0_y0.tif (max, radius: 0.1, resolution: 0.05)
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x0_y0.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpHEe0af.json > /dev/null 2>&1
[DEBUG] running pdal pipeline -i /tmp/tmpGzQPJK.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x0_y0.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpaHPmAp.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x0_y1.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp8Wlh3m.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x0_y1.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpfLZj0X.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x0_y1.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp2OrW50.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x0_y2.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpRZPhYQ.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x0_y2.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmps5u1QS.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x0_y2.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmppKSoWi.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x0_y3.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpAdCdAO.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x0_y3.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpUQpqu1.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x0_y3.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpxTC7Fs.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x1_y0.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp79TqXG.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x1_y0.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpnQWNI1.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x1_y0.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpApOQbZ.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x1_y1.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp4M_KS8.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x1_y1.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpXCZHXG.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x1_y1.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpcnFG2v.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x1_y2.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpn_EYrn.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x1_y2.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpsKTnnN.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x1_y2.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpGERRdV.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x1_y3.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpnrNcAl.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x1_y3.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpZc_iJv.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x1_y3.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpxr160z.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x2_y0.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpGcR2ne.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x2_y0.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpTADwzO.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x2_y0.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpKDOYt4.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x2_y1.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpgjTpTq.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x2_y1.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpziOTfF.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x2_y1.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpJgd5sj.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x2_y2.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpmJCUXZ.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x2_y2.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp9dgLZj.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x2_y2.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpi5ZEYk.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x2_y3.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpFeEvva.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x2_y3.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp02ig8D.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x2_y3.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpGh0INl.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.025_x3_y0.tif (max, radius: 0.025, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmp1MfYex.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.05_x3_y0.tif (max, radius: 0.05, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmptzmhO4.json > /dev/null 2>&1
[INFO] Generating /var/www/data/5ff6cadd-737b-4045-a6db-4964f36c3965/odm_dem/dsm_r0.1_x3_y0.tif (max, radius: 0.1, resolution: 0.05)
[DEBUG] running pdal pipeline -i /tmp/tmpggusCe.json > /dev/null 2>&1
Please help me on this. Thanks
Hey @sasa :raised_hand: this could be a bug.
Mind opening a bug report on https://github.com/OpenDroneMap/WebODM/issues with some additional information / screenshots?
