Cannot create virtual machine error
Hi! Could somebody help me address the issue with the error log that’s found below. I have no idea how to get around this. Hope someone can assist. Many thanks!
[03]: Hyper-V Virtual Ethernet Adapter
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Initializing console…
OpenSSH check passed
‘docker-machine’ is not recognized as an internal or external command,
operable program or batch file.
WebODM VM does not exist. We’re going to create it now… hang on tight! If this takes more than 10 minutes, please try restarting your computer.
create --virtualbox-no-vtx-check --driver virtualbox --virtualbox-disk-size “150000” --virtualbox-memory “7302” --virtualbox-cpu-count “4” webodm
Uh oh! Check the console. Check that you have enough memory available, disk space, that your firewall is off and that you have restarted your computer. Refer to the troubleshooting section of the installation manual for more information.
Try installing Docker Toolbox manually. https://github.com/docker/toolbox/releases/download/v19.03.1/DockerToolbox-19.03.1.exe it looks like a program needed by the application is not available.
